I just Dumped a Proscan 10.1 PLT1044 , its a AllWinner Boxchip A10, I need some help
Originally posted by elektrik View PostOk, so it looks like there's only partial SU and no google play, so I could probably add those without too much difficulty, but honestly, I bet all you'd have to do is drop a superuser.apk and a vending.apk into /system/app, change the permissions and you'd have root & google play (that's pretty much all I had to do for my ROM.)
...as for debloat, the only one I see is the Tango app and maybe the galaxy4.apk (but I don't know what that is for sure...
Bakgrounds? Kinda silly to make a custom ROM for backgrounds-that's what "Titanium Backup" (free version in google play) is for :-)
I think pretty much what I want is a rooted rom. It doesn't have to be custom, Unless you want to customize one.
Originally posted by rlmiller View PostTried that i think he changed something in the system files
Tell me what options in recovery you have-can you flash a .zip file...? I wonder if this thing works with Live Suite since it's an Allwinner..... A10....
...in the meantime I'm downloading another of their firmwares to see if they're using Live Suite (which I suspect they are.)
Originally posted by bryman777 View PostSo what program do you use update your rom file to your tablet, Odin ? or do you use the update.img from the update on the tablet.
Originally posted by elektrik View PostWas that question for me? If it was, we use a program called "Live suite" from the developer to flash an image (or once we have CWM via kkromkit or my own (newly released) elektricity ROM, we can flash ROM's from a zip file).
Originally posted by elektrik View PostHoly crap-I just looked at their website and they don't even have an image!!!
Im assuming its an Update.img file ..
Originally posted by bryman777 View Postthere`s a backup&reset , in the settings. theres a system upgrade option, then it say`s recovery mode, Reboot into the system in recovery mode,. Can clear the data, or system upgrade.
Up to you...let me know quick cause I'm leaving soon.
apply update from external storage
wipe data/factory reset
wipe cache partition
apply update from cache
Originally posted by elektrik View PostLike I said, I can probably try to make an image based on the dump, but I make no guarantees since I don't have one of these tablets-you could make it worse.....
Go for it, If I feel real gutsy, ill try it,
if it gets bricked, its back to big lots.. lol
Originally posted by bryman777 View PostGo for it, If I feel real gutsy, ill try it,
Right on, Should I drop it on an sdcard then run through the backup restore? I also found a 800 number for proscan, im going to try and also get a back up image from them in case something goes wrong.
Well that went well, I asked for backup firmware, this is the response" Sorry sir no update firmware for your device because its brand new, no firmware for it, I have just about as much information as you, because its new."
Originally posted by bryman777 View PostRight on, Should I drop it on an sdcard then run through the backup restore? I also found a 800 number for proscan, im going to try and also get a back up image from them in case something goes wrong.
There are currently 2619 users online. 9 members and 2610 guests.
