UPDATED September 20, 2013!![ROM]Elektricity ROM (703C)
    That appears to be the version for GingerBread. I grabbed gapps-ics-20120304-signed.zip from goo.im, kept all the stuff in the /system/lib folder and /system/app/Talk.apk - deleted everything else then installed in recovery. Works great.
      Coming soon: elektricity ROM-GINGERBREAD
      keep an eye out...I'm close :-)
      https://public.bay.livefilestore.com...ion.png?psid=1
        That's what she said?
          oh...kay.....
            Youtube sign in trouble
            I'm having trouble signing in to YouTube I've checked the accounts but there's only 1 not sure whats going on here
              I think this is more of a "general support" question, unless you have a specific reason why you think it's related to elektricity ROM....
                Well not really just wanted to see if anyone else had this issue from what I've got from Google most people say its having two accounts syncing but that's not my case guess ill have to do some more digging around thanks though Rom worked really great, liking it.
                  I can attest to the 'dual google account' thing-I tried to install something from the play store on my test tablet and realized I was using my test account, not my main one, so I added my main one and Google choked, lol.
                    Re: Elektricity-UPDATED January 14, 2013!![ROM]Elektricity ROM
                    Hey E,
                    Are you progressing on the Jelly Bean port from Onda? Just wondering, since I rolled back to your v2 rom, and miss JB
                    Sent from my 701c with tapatalk
                      Originally posted by jtintle View Post
                      Hey E,
                      hey! not as well as i'd like. onda's beta is just that. the problemI keep having is that the menu/back keys aren't working-despite havin all the proper things in place (I don't feel bad, because even Onda's stock beta has the same problem!) so either I wait for Onda to get their crap together or I build my own jb kernel (and with work/life getting busier, that seems to be less and less realistic)
                        ok thanks for the update, guess I'll run what I got until my taxes get here and I decide on a new tablet
                          Hey E,
                          In you Elektricity v2 rom, did you have a dictionary source included?
                          If not you might want to check this thread out from xda:
                          It might now use the same files but you would know what files you need.
                            Hey E,
                            Hmm...will check it out....
                            Thanks!
                              Google Play Problem
                              Ok, so I just flashed your new GB version of Electricity for my 701C. It is super fast and I'm loving the ROM. Only problem so far is the Google Play store is giving me a problem when I try to purchase an app. Works fine for free ones. Recommendations online say to remove updates, and clear cache, but it doesn't give me an option to uninstall updates in the app management. Any help??
                              << OK, ignore my idiotic post, I was using my kids account which doesn't have a CC attached to it. All's good >>
                                no, it's totally cool-Google Play doesn't play well with multiple accounts too so be careful with that.
