What other apps are you having problems with? Would like to try installing...
UPDATED September 20, 2013!![ROM]Elektricity ROM (703C)
Originally posted by s'pht View Posthangouts *installed* fine but wouldn't run on the previous version since it didn't have Google Play Services
Originally posted by ftajones View Postthis is what I was talking about
Originally posted by elektrik View PostI said that without testing it myself at the time. When I tested the ROM and found out that Google Hangouts installs perfectly, I decided against changing anything-if it ain't broke don't fix it. I haven't heard from the guy who posted that-whether reflashing his ROM worked so I'm assuming it was his device until I hear otherwise.- installed firmware with format option
- added wifi credentials
- added google account
- went to play store and updated the stuff that was there
- installed hangouts
- loaded it:
- "Google Play Services, which some of your applications rely on, is not supported by your device. Please contact the manufacturer for assistance."
- rebooted the device
- same error on launching hangouts
- Installed Google Play services_3.2.25 (761454-36)
- Install of play store 4.3.11 fails: Failure [INSTALL_PARSE_FAILED_INCONSISTENT_CERTIFICATES] (I expect this means the play store in the ROM isn't signed with the official keys so it can't be updated in-place)
- Used TiBu to remove Play Store 3.5.16 (8011016)
- Same error installing play store 4.3.11, must need a reboot
- rebooted device
- Installed Play Store 4.3.11 (8023011) yay!
- Hangouts works fine, logs in and I can send/receive messages.
- EDIT: and don't forget to move both to /system using TiBu or you'll get force closes with Play Store all the time.
Originally posted by s'pht View PostI just tried installing 0.40 on a 701c today (this was a different 701c, I used to have 3 but I only have 2 now - one was replaced by a 704):- installed firmware with format option
- loaded it:
- rebooted device
I must say I have been wanting this Rom for a long time now and was never able to because Livesuite would not work on my Windows 8 so I finally came across PhoenixSuit and it worked. Nice ROM!!! Now my daughter can actually use her tablet!!! Looking forward to some more.Maybe a JB Rom. Nice job, elektrik!!!
Originally posted by PTAB7X View PostFor those how have a PTAB7XC, i installed the 703C_elektricity_rom_v_031-STABLE on it for testing
Thats make 4 days now, and i seen 0 issues, everything works (google play...3rd party apps...wifi)
There are currently 1859 users online. 0 members and 1859 guests.
