Using the information provided by James Cozzby and Silicon Orb, I managed to get my tablet installed in Device Manager and found by ADB. I used the "Universal Serial Bus" procedure provided by James for the Device Manager and then, using the information provided by Silicon Orb, struggled through updating the Path and INI file to solve the ADB problem. So finally I was ready to try to root my tablet!!
I got my Bin4ry set up and checked my tablet settings and then clicked the RunMe file, typed 1 and pressed enter. The root process started and, when asked, I pressed restore and the tablet did its first reboot. Unfortunately, the tablet screen went black and stayed black. I waited about 10 minutes but the tablet screen stayed black. I unhooked the tablet and tried doing a reset but nothing happened. Now, when I first press the reset button the splash screen loads and, if I do nothing else, the screen goes black after 5 seconds. Sometimes, when I push the power button while the splash screen is on, a small green android appears on the screen. The android is lying on his back and has a red triangle with a black explanation mark on his chest. I am not sure what combination of button pushing and touching the screen causes the android to appear. The adroid stays on the screen for about 30 seconds and then the screen goes dark (it appears that there is a very faint background light in the screen that goes black when I first push the reset button). Also, when I plug the tablet usb cord into the computer, I get a recognition sound from my PC and the tablet shows up in Device Manager but the tablet does not make any sounds. The ADB DEVICES does not detect the tablet.
Any idea as to what I should try next?
Bruce
