Thanks for your help
USB ports dont working
Originally posted by alekmzn View PostAfter one day, The USB ports of my pipox7 left working . hdmi, and ethernet ports work correctly but i cant use mouse or keyboard . Any idea for solving it?
I have the same problem if I connect an external SSD drive, all USB devices strop working, I guess the SSD draws too much current.
The solution would be to use a powered USB hub but I haven't tested yet.
Originally posted by CRi View PostDo you have anything else connected to the USB ports?
I tested a hub with external power. with that; the mouse has the light on but continues without working.
Originally posted by alekmzn View PostNo, nothing more. I tested, mouse, keyboard... with de same result.
Did you install a software to remote control your pipo (teamviewer, vnc,...) ?
Had you also tried another PSU (12V/>=2A)?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by alekmzn View PostNO,
I have only used the original.
Could work with another power supply? Which could be an appropriate one for the pipo x7?
Originally posted by lunnik2 View PostA mouse and keyboard are working with one usb adapter? I mean, what if the problem is not in the ports? You tried to connect other mouse? And if you just stick the USB-drive, has some sort of reaction?
I tested:
A wifi keyboard + trackpad (logitech k400), the first day worked fine, the second day left working in the pipo.
A wired optical mouse, that doesn´t.
Both items works correctly in other tablet and pc.
I haven´t try a usb drive, i will test it this night.
Have you tried plugging the wired mouse in all four USB ports? Make sure to use only one of the four ports at a time and leave the other three free, to avoid any probable electrical shorts.
You should also check if the USB ports provide correct power. If you do not have the proper equipment, try to charge a mobile phone. As above, check each one separately.
Originally posted by loko View PostMaybe your power adapter is causing all the trouble.
Before returning the device, check it with another 12V power adapter from an old modem/router, even if it is rated only 1A.
Thank you!
There are currently 5041 users online. 0 members and 5041 guests.
