[GUIDE] Enable MeeGoPad Auto Power On
Guest
really strange...
Did you tested it if some settings in the BIOS are responsible for this problem?
Originally posted by dirtyballs View PostI download it, flashed it to a meego with only windows 8.1.
first time I switched off and on the power ( 220v ) Nothing happened.
after unplugging the USB it started very fast, very fast ~4 sec
so switching of the power off and on will not trigger reboot, the power supply keeps voltage on the USB.
So confirmed dis BIOS update works. typed this message from updated meego.
Now I need to do it to my multi boot, I am first going to make a full backup BiOS and mmc :-)
DB,
thanks Stewart
I have a meegopad T02 with BIOS version: 5.008 Project version: T02 0.18 Build Date and Time: 05/25/2015 09:40:05
I am wondering if the T01 BIOS OEM version will work on the T02, my current BIOS only has basic options in it, no advanced menu etc so I cant get auto power on to work.
An obvious difference between the T01 and the T02 is the additional USB port,
It appears that it may be possible to get auto reboot after power loss by a different method by writing to a register that tells the stick what to do after various power state tansitions, for example here http://smackerelofopinion.blogspot.c...ci-s-01f0.html
I have downloaded the intel reference document but I am not sure what address on the ISA bridge adapter where this register lives, hence now I am thinking about flashing the T01 OEM bios instead.
Hello, i have a meegopad T02 since yesterday,. I'm stuck on diagnose boot, i've tried a lot of solution. I can't go to command prompt so i can't flash T02 by this way.
Maybe a hard flash like here http://www.cnx-software.com/2015/05/...hdmi-tv-stick/
But i need a T02 oem bios for this.
It's impossible to boot on an usb flash drive ( bios without options to enable it )... Help needed
Originally posted by Bono2007 View PostHello, i have a meegopad T02 since yesterday,. I'm stuck on diagnose boot, i've tried a lot of solution. I can't go to command prompt so i can't flash T02 by this way.
BIOS recovery needed, not tried this but I came accross the article on my travels for unbricking? try this https://www.bios-mods.com/bios-recov...bios-recovery/
Originally posted by x0vash0x View PostHi! can someone modify a version of T02 bios? because when i used the T01 to my T02 the wifi is not working.
I've spent quite a long time looking for a solution for this and not succeeded.
There are two main ways to "unlock" an AMI bios to gain access to hidden menus, yes the T02 does have an advanced and a chipset menu but it is disabled, and the power option is there under the Advanced menu, Miscelaneous, "State after G3" - but the default is S0 which is what you want for auto power on???
The 1st method uses amibcp to edit the menus to make them visible, however amibcp is unable to "save" this bios, it can open it, but not save it an error occurrs, even if you have made no modifications.
the other method I found was by dumping out the setup part of the bios using UEFItool and using a hex editor and finding the table of enabled and disabled menu entries, the method does not work on this bios. I cannot find the required sequence of zeros and ones.
Now, having given this some thought, theres a good chance that even if the menu was to be enabled that changing the power on settings might brick the T02 anyway, after all we know that this has happened on the T01.
I have now given up on trying to do this and bought a battery backup instead to keep my T02 powered on, in my application my T02 will be in a remote location and running 24x7 monitoring and controlling my central heating system in a holiday home. Using a "powerbank" that allows both charging and using at the same time effectively turns it into a UPS. I've just ordered an Anker 10,000mAh which has been verified in the raspberry pi community as suitable for this, ie you plug it into a USB charger and plug your T02 into it and interuptions in power are avoided due to the battery, and a run time that could be as much as 12 hours.
The anker 10,000mAh battery has arrived and unfortunately it does not provide power at the same time as charging :-(
Is your T02 activated (so your BIOS includes your Windows product key)? Can you post a just a picture of your BIOS version or post its 'Project Version', 'Build Date and Time' and 'Microcode Patch' from the first screen on the BIOS please? There seems to be a few T02 BIOS around at the moment and it is not obvious what the differences are.
Normally activated.
From the efi shell, if i prompt ver i have : EFI Spec revision : 2.31 and revision 5.31
I've tried 3 usb sticks (usb3 and usb2 ), formatted as FAT32, with GPT partition table for UEFI.
Read more: http://www.cnx-software.com/2015/01/...#ixzz3dxyhSTYP
But no boot from usb choice after F7, only boot from uefi shell and windows command.
Originally posted by scote View Post
well your brave flashing a T01 bios on a T02, now I know what happens without risking bricking my own T02.
There are currently 1766 users online. 1 members and 1765 guests.
