[GUIDE] Enable MeeGoPad Auto Power On
Originally posted by x0vash0x View Post
Actually it worked! the modified T01 BIOS to my T02 but the only problems are the wifi and bluetooth. The rest are ok and working fine and I'm using usb ethernet to connect on the internet. But its 100% ok if someone modify the T02 bios same like T01 XD
It is ok that wifi and bluetooth will not work with this BIOS, but I need the advanced BIOS Settings to enable the Intel turbo boost mode.
Originally posted by Rick-Nash View Post
please help - where can I find this modified T01 BIOS? I have to be sure that this BIOS will not crash my device.
Here you go -
Auto Power on (after power restore), Wifi and Bluetooth working also with the updated T02 biosUpdate your T01 to the latest BIOS Note: continue on you're own risk! MeeGoPad will not repair bricked devices caused due to BIOS update attempts! 1: Download the latest BIOS for T01 2: Unpack, and rename the unpackeLast edited by Stealth; 08 October 2015, 08:59.
I have a clean install of Windows 10 Pro on my T02 with the T02 Auto Power Bios. Inbuilt WiFi, Audio and Bluetooth also working fine. If you do a fresh clean install you will need the T02 drivers for the audio and screen resolution (otherwise the Windows Basic Graphics driver will be loaded which only has a resolution of 1920 x 1080). Took my ages to find them so here they are - Use the PlatformInstaller option.
Good Luck.
Originally posted by Stealth View PostI have a clean install of Windows 10 Pro on my T02 with the T02 Auto Power Bios. Inbuilt WiFi, Audio and Bluetooth also working fine. If you do a fresh clean install you will need the T02 drivers for the audio and screen resolution (otherwise the Windows Basic Graphics driver will be loaded which only has a resolution of 1920 x 1080). Took my ages to find them so here they are - Use the PlatformInstaller option.
Good Luck.
Hello,
I have a T01 meegopad by accident while I'm in the system, I disables the operation of usb, now neither smiled nor the keyboard is not working. Because of that I can use my T01.Quand I plug my T01 is just the screen which opens the system. Is that there is someone who can help me please.
Thank you
Hello,
I have a T01 meegopad by accident while I'm in the system, I disables the operation of usb, now neither smiled nor the keyboard is not working. Because of that I can use my T01.ifI plug my T01 is just the screen which opens the system. Is that there is someone who can help me please.
Thank you
Originally posted by stewartie4 View PostThere are options in the BIOS but these will brick your stick.
I just bricked my T02 with an unlocked BIOS that might have had some features enabled, would you like to share what features that bricks the stick when enabled?
I guess I'll need a programmer to restore the bios at this point, no red led when power on (USB get power though) and black screen.
Thanks for you work, really appreciate it.PIPO-P1@1.6GHz
ROM: RileyROM 1.7CX-919@1.9GHz/798MHz/800MHz
ROM: Finless 4.4.2 BETA
Kernel: D33's AP6210 HD v3.00 +noderat OC
Fan mod: Outside & inside + Antutu: 23694 & Stability test
Thanks for the post. I followed the instruction and successfully made my meegopad t01 auto power on!
Now the question is: How do you guys protect the pc stick from power cut? I mean, if you power on the meegopad t01 directly from TV usb power source, how do you guys protect the PC stick from the direct power outage once turning the TV off? I guess we will need to use something like ups power supply or some pcb board to delay the power loss and send the PC command to turn off? Thanks..
There are currently 4820 users online. 0 members and 4820 guests.
