HPH new firmware-150306
Originally posted by Shadi86 View Post
Originally posted by Shadi86 View PostWill go back to the previously firmware it's so far the best and the passtrough work fine on it.... We need better Progress for every new rom, I know its on beta and it's not 100 , but the passtrough was working good on the other old rom but not on this new rom, it's strange, hope Tina can look at it
Originally posted by mo123No one want to test my new ROM and give feedback to make it better?
I cannot get the USB driver installed. It said fail every time.
But when I run the flash tool, it said One ADB Device Found.
Is it normal and OK to perform the flash?
Just to play safe and reduce the chance of bricking.
Last but not least, ADB and Loader Mode uses two different drivers, so if ADB works it doesn't mean that Loader Mode works (it only works if you had installed the correct "RockChip Class Driver")... But, because your PC is able to detect the box at ADB (while running Android) you should also be able to install the correct drivers if the box is at Loader Mode (as mo123 described above)...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostLast but not least, ADB and Loader Mode uses two different drivers, so if ADB works it doesn't mean that Loader Mode works (it only works if you had installed the correct "RockChip Class Driver")... But, because your PC is able to detect the box at ADB (while running Android) you should also be able to install the correct drivers if the box is at Loader Mode (as mo123 described above)...
Finally get to flash the rom. USB driver is a bit tricky on this little beast.
Got it up and running and really loving it!!
I can confirm at least on my side, SPDIF OUT with the SPMC in this ROM really rocks!!
I setup SPDIF OUT in Android Settings, with PASS THROUGH IN SPMC, and my AMP really detects a movie with DTS output correctly. Even with the format of DTS. (ES in my case)
With HDMI bitstream in ANDROID Settings, and audio out with HDMI cable, SPMC or latest KODI cannot detect the correct DTS format, in my case.
But I still cannot get to work is YOUTUBE 1080p. It's still capped at 720p in my case.
Need some more time to play around.
Originally posted by mo123In my HPH v1.5 ROM, 1080P Youtube is working great.
http://www.freaktab.com/showthread.p...-v1-5-by-mo123
MO123 ROM 1.5
There are currently 2106 users online. 1 members and 2105 guests.
