HPH new firmware-150306
Guest
Originally posted by bloatman View Post
MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
I'll post the changelog when my download finishes. If no one outruns me in the meanwhile.
Originally posted by Burs View Post
I finish download. The change log is in Chinese. As I am Chinese speaking, let me help translate the change log (since 01-29-15)
2015-03-05 a0146e9 Android->Google:Update Google Services Gms(playstoreservice),Phonesky(play store), Gms will be installed alone at startup
2015-03-05 7fc120e Kernel->nfs:NFS function enabled
2015-03-02 671f632 Revert "Kernel->HDMI:Support HDMI passthrough by writing display0.HDMI as output"
2015-03-02 99612f7 SDK->HDMI:Resolve issue of noise interference during HDMI passthrough
2015-03-02 9efe5c8 Android->wlan: WIFI now supports channel 12,13
2015-03-02 1c90e1f Android->media:Resolve randomly crashing of media server
2015-02-27 af45842 Merge branch 'master' into tchip
2015-02-10 fced928 Android->miracast:Group broadcast added,resolve the problem associated with LeAssistant searching with some routers
2015-02-04 cf923dd hdmi: use irq mode.
2015-02-03 5b58b1b TCTools->imagetool:Burning tool AndroidTool default language is now English
2015-02-03 7df8bcc Android->DeviceTesturing uncopy,AgingTest, the import error during the loading of the test document is resolved
2015-01-30 3d1c1b6 save 3d state, if 3d state changing then reset viewport
2015-01-30 8f7a237 Merge branch 'master' of ssh://10.10.10.211/rk3288/box/4.4.2_r1
ORIGINAL CHANGELOG in Chinese:
2015-03-05 a0146e9 Android->Google:更新谷歌服务Gms(playstoreservice),Phonesky(pla y store),开机单独安装Gms
2015-03-05 7fc120e Kernel->nfs:开启nfs功能
2015-03-02 671f632 Revert "Kernel->HDMI:支持HDMI通过写display0.HDMI进行输出"
2015-03-02 99612f7 SDK->HDMI:解决直通开始时杂音问题
2015-03-02 9efe5c8 Android->wlan: wifi支持信道12,13
2015-03-02 1c90e1f Android->media:解决mediaserver概率性崩溃问题
2015-02-10 fced928 Android->miracast:加入组播,解决乐家助手部分路由无法搜索
2015-02-03 5b58b1b TCTools->imagetool:烧写工具AndroidTool默认语言为英文
2015-02-03 7df8bcc Android->DeviceTest:修改uncopy时,AgingTest测试文件传入错误的问题
This is an impressive update. I flashed through the TF / USB Drive method.
So far two of my major problems with previous firmware (0129) are solved:
1) Miracast: I can connect my VEGA A880s to HPH now (previous firmware fail to connect). Though not very smooth.
2) With latest KODI I downloaded myself, HDMI passthrough works!! In previous firmware, I got problem with many movies.
3) It's the first time, in ANTUTU Video tests, all tests are passed!! (The tests are passed but I found test clips with ac-3 audio did not produce normal sound during the test, don't know why)
So far this is an impressive update from Nagrace. Really well done.
firmware
Hi, i need some help, i download the firmware from Mega, after done, i decompress, rename fullpackage.zip to update.zip, move to SD card ( all into my laptop) insert the SD card in the Nagrace TV box and it detect the update, after i accept to update, need to reboot and after get back in the screen say something is wrong with update and ask so i want to delete it to no ask more about new updates. Please, what is wrong or i mistake. Thanks
Originally posted by Shadi86 View PostThe spdif passtrough don't work for me in the spmc on this firmware
My Settings is as follows:
HPH BOX Settings:
Android Audio setting:
HDMI Passthrough
KODI Audio Setup:
Passthrough enabled,
AC3 Capable Receiver - ENABLED,
DTS Capable Reciver -ENABLED
Enable Dolby Digital Transcoding - DISABLED
Hardware connection:
HPH --> HDMI --> TV
HPH --> SPDIF --> AMP (my old AMP does not have HDMI input)
Both the TV and AMP can have proper sound output. DTS is available on the AMP.
Originally posted by Kanchata View PostHi, i need some help, i download the firmware from Mega, after done, i decompress, rename fullpackage.zip to update.zip, move to SD card ( all into my laptop) insert the SD card in the Nagrace TV box and it detect the update, after i accept to update, need to reboot and after get back in the screen say something is wrong with update and ask so i want to delete it to no ask more about new updates. Please, what is wrong or i mistake. Thanks
For some reasons, Rockchip is extremely fond of Windows based firmware tools, and instead of providing a simple SD card method, they've continued to use
I never use it though, so flash it on your own risk.
Originally posted by bloatman View Postmaybe I won't try it yet, perhaps the mega file is corrupted?
I really wish they would start running checksums for these DLs. I DL a lot of Linux distros(reformed distro junkie), using the checksum checker in the Firefox plugin Downthemall, sure makes that more fool proof. Back in the day, when I had to burn distros to CD/DVD because my PC did not support USB boot, I wasted many discs on corrupt DLs. MD5, SHA* or whatever, checksums insure accurate DLs. In the case of distros, it was just a wasted disc and time. With firmware the results can be far more troublesome.
Whether using the feature in Downthemall or a stand-alone checksum generator/checker, it takes very little time and effort to add/confirm a checksum.
Just my 2 cents. Ok I may have thrown a couple of more pennies in, that I found under the couch.
Still, it's just my opinion.
I'll get out of your thread now.
Guest
I wouldn't say it's a bad download (although it can be). But do this first: if the zip file extracts without errors, and if update.zip (or .rar for AndroidTool) extracts without errors, you can be pretty sure it's not a bad download. Zip and rar archives also have checksums (although not as strong as sha1 or md5), but crc32 is also very sensitive to data corruption. And if it happened to me, it wouldn't be the first time I had to flash it one more time for the damn thing to fit in properly
There are currently 2749 users online. 0 members and 2749 guests.
