Youtube App capped at 720p?
Originally posted by Boxx View Postthis is an easy fix but please be aware that it may cause unwanted side effects!
you don´t need a modified apk at all.
added: in order to make it work, the navigationbar at the bottom of the screen has to be disabled. if you leave out the qemu.hw.mainkeys=1 or if you set it to 0, no 1080p option will be available. not sure why this is.
so if you don´t want to loose the navbar, then no 1080p youtube for you, sorry. if you need a navbar, maybe you find a replacement for the built in one. i don´t like/don´t need it and disabled it anyway.
IMPORTANT: if you set the wrong permissions for build.prop, you will get a bootloop!
make sure it is set to:
0:root (owner and group), 644
before rebooting your device!
1.backup your original build.prop (located in /system) in case you need to restore
2.search for the following lines:
Code:ro.product.model=Draco AW80 ro.product.brand=Tronsmart ro.product.name=jaws_tvd_p1 ro.product.device=jaws-tvd-p1 ro.product.board=exdroid ro.product.manufacturer=Allwinner
Code:ro.product.model=Nexus 10 ro.product.brand=google ro.product.name=mantaray ro.product.device=manta ro.product.board=manta ro.product.manufacturer=samsung
5.save build.prop
6.(maybe optional)go to android settings>apps>youtube and clear data.
7.reboot. done!
this should work on every rom.
tested on Draco AW80 20150318 firmware
What do you use to navigate now that you have removed the navigation bar?
Pie controls though Gravitybox?R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by dodongdodong View PostSorry for noob question, how do you set permission to build.prop?
if you edit the file directly on the box in /System, you dont Need to worry about permissions because they wont Change.
btw. i will add today or tomorrow how to Keep the navbar, how to set 1080p as Default in yt and how to enable 1440p.
There are currently 6378 users online. 1 members and 6377 guests.
