Stock Firmware - Beelink S82 Plus - Official FW Releases from Beelink
Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use).
Second question, is anyone else having an audio cutout while watching videos/listening to music on KODI - I had lots of 1/2 or less second audio cutouts with Kodi 14.2. Tried Isengard Beta 2, which seems to have fewer cutouts, but still has the problem. I have had this both with Ethernet and wireless (5.0 ghz - am close to router). This is why I am trying a firmware update.
I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party.
Ron White
I have read all the posts in this threads and I am confused, currently I am using 202k4 is this the best and most stable version ?
and also, are they going to have OTC firmware updates ?
I have it running for 3 weeks and seems to be working fine. My main problems was older versions did not have spdif output configuration part done, so this version fixed that. Other than that, all good.
I run music from kodi all the time without problems. But my setup is box to spdif to receiver. Yours might be different.
I've just gotten this little box and I'm fairly happy with it so far. Just some small annoyances like unsaved changes after restart and such (I can live with those). My main problem is that my screen is flickering and turning black for 1-2 seconds every now and then. Sometimes it's 10 min between and sometimes it's 10 seconds between.
The hdmi auto-detect comes up at 720p 60hz and that's not good since my tv is 1080p, can that have something to do with it? I've changed manually but that doesn't change anything.
Does anybody have any ideas?
I've just upgraded from 201 to 202 firmware but if anything it got worse....
Thankfull for any help!
Hello friend,
Please give me your order number.
I will tell our sale to contact you as soon as possible
This ROM seems fishy. Same firmware build but with all these XBMC variants pre-installed and a different date? I dont buy that this May version is actually from Beelink. My factory installed 202K4 has a March date and until I see someone else I trust from this site say that it's ok, I'm staying away from this.
Can someone confirm the legitimacy of maliay and the ROMs he is posting ?
I read your review, it sounds like the 201k4 is the most stable.
I was unable to download from the fast link but here is another from china gadgets, and it's zip sd.
I am on 202K4 and as with others I also noticed a audio sync issue. Interestingly enough, the problem seems to have gone away when I enabled hdmi passthrough in the mbox settings. Youtube and vevo from play store seem much better but maybe my brain has adjusted to compensate for the delay
