How do you move apps to SD card
There are many apps already installed in this folder wasting our minimal storage space. As a non app store example I have kodi installed on external hdd but it still uses up over .5gb of storage on the hard drive because it needs kodi files in the windows user folder to operate properly just like Google Chrome does. So I feel that the issue should be discussed to see if there is a way in 8.1 to install windows apps to the SD card. Is the SD card just for media? I'm just trying to find a way to increase storage space as windows updates over the next year or so will eat up a significant amount of the remaining 10 to 13 gb of storage space remaining after the system is set up with in my opinion just the basics more or less.
Sometimes it's also helpful to use the portable version of an app/program (e.g. Chrome because it stores download first at 'internal store' (a directory) before it move it to the destination folder) so you can chose where to place it...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostSometimes it's also helpful to use the portable version of an app/program (e.g. Chrome because it stores download first at 'internal store' (a directory) before it move it to the destination folder) so you can chose where to place it...
Kevin
There are currently 1852 users online. 0 members and 1852 guests.
