There are so many guides I am unsure how to do this for a XT-Q7-V11.
How can I backup/restore my firmware ? (XT-Q7-V11)
I would use this one, because you also learn something about the partitions and how to customise the AndroidTool...
(I use this way at every new rk device I get)
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostI would use this one, because you also learn something about the partitions and how to customise the AndroidTool...
http://www.freaktab.com/showthread.p...ew-RK-2-1-tool
I tried the instructions but I get this error on this step "Now press the export image button."
Please see attached for the error.
I am thinking it may be because my device is not in loader mode ( I am unsure how to do this for Android boxes)
Yes, your device is not at bootloader mode, it's running at android
You have to press the reset before and while you power on (by plug in the PSU (you have to manage it by plug in the PSU because the box will boot automatically because of the connected OTG port)) the device to get it to bootloader mode...RK3288 Devices
Originally posted by no_spam_for_me View PostYes, your device is not at bootloader mode, it's running at android
Sorry, I am unsure how to do this with my Q7. I have a recovery button on the bottom but I'm unsure of the sequencing that is needed to activate bootloader mode.
Start AndroidTool
At Box:
1. unplug PSU
2. plug/connect OTG at box with USB at PC (if not already done)
3. press reset (recovery button on the bottom) and hold it pressed
4. plugin PSU
After a short moment the AndroidTool should show something like "Found Bootloader device" and now you can release the reset
OR install http://www.freaktab.com/showthread.php?1050-Reboot-App and reboot to bootloaderRK3288 Devices
Recovery is another thing... You try to start the device at bootloader mode...
What das it mean if you wrote "I was able to get my PC to pickup the device" BUT then you wrote "my windows 7 PC cannot recognize the device" ???
Bootloader needs another driver (rockchip class...) but your PC has to recognize the box as unknown device...
It should work with the 4.1.1 which you can find here http://www.freaktab.com/showthread.p...l=1#post219459RK3288 Devices
Originally posted by no_spam_for_me View PostRecovery is another thing... You try to start the device at bootloader mode...
I am on windows 7 64bit using a XT-Q7-V11 (CS918).
Is this a driver issue or drive and mode issue ? How can I get flash tool 1.37 to read my device ? (I find it somewhat strange because Android Tool v2.1 can pickup my device as a loader)
I don't know why AndroidTool 1.37 do not see your device but 2.1 will do (maybe because of newer driver? or because of 64bit? or...? I don't use 1.37 since 2.x exists)... But you can also use 2.1 to flash your device...RK3288 Devices
There are currently 2339 users online. 0 members and 2339 guests.
