Need Help Unbricking Mk809III (win 7 won't let me change drivers?)
Has anybody had any luck installing new drivers on the MK809III using windows 7? I can get it to pick it up as a usb mass storage device and it even shows up as portable devices in the device manager but no batch tool i tried will recognize it and windows 7 won't let me install any new drivers manually! Holding the reset button also does nothing for me, any help would be greatly appreciated....
ThanksTags: None
Oh man... I've been there with all the driver troubles. NOT FUN!!!
In the Rockchip Assistant tool, you should see a file called setting.ini. Open that to edit it, and change SUPPORTUSB11=0 to SUPPORTUSB11=1
Try running the driver tool again and see if it detects it. I doubt it, since you said your problem is that it's reading as mass storage device. But I figured it's worth a shot. You could also try reading my thread with some of my issues. I have other threads with driver issues, but I can't find them right now: http://freaktab.com/forum/tv-player-...-start-code-10
There are currently 1379 users online. 0 members and 1379 guests.
