JustMe 1.7 Ported ROM [Members Early Rls] due to roll out tomorrow
Originally posted by djjinx1 View Post
OP post updatedBugs are Sons of Glitches!
JustMe
Just found out..And new firmware 1.7a is updated..Here make a note just in-case you are run into this issue
In my case, I have to do:
1.Uninstall kodi
2.Re-Flashed v1.7 (Previous release)
3. No kodi install yet
4. Update/Backup (This folder in Main Apps)
5. Flash new firmware 1.7a..........
HOLA........Work like a champs
JustMe
There are some issues was happened from previous 1.7 but still remaining on this new upgrade 1.7a
1. Random ERROR button appearing, everywhere in kodi
2. Screen still not center....
3. XBMC on front page still doesn't exit...(Nothing if click on it)
4. Crash on some of IPTV (.m3u) files (Previous 1.7 ran great on those .m3u files)
5. press power button to turn of the box then press power button again..Box is on but no output to TV..
6. faster Rolling wheel on mouse kodi will crash to Main page.....
you need to start fresh you probably have clear you cache from old 1.7. no need to load old 1.7 just use new 1.7a via toothpick or android UI upgrade/backup. maybe load older rom(1.5v3) and then upgrade to 1.7a
power button must be quick short press not a long press, also as stated in email you need to download kodi helix or isengard as its not part of the rom.Bugs are Sons of Glitches!
JustMe
check your gmail junk/spam box update was sent yesterday.....Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postyou need to start fresh you probably have clear you cache from old 1.7. no need to load old 1.7 just use new 1.7a via toothpick or android UI upgrade/backup. maybe load older rom(1.5v3) and then upgrade to 1.7a
@JMR
So in general just stay away from previous 1.7...Then 1.7a flashing OK?
Ericlupori & rahjer
Google updated today
download and install Google Play services 7.0.99 (1809214-836) link : - http://www.apkmirror.com/apk/google-...-apk-download/
download and install Google Play store 5.8.8 link : http://www.apkmirror.com/apk/google-...-apk-download/
this should fix your login issues
@TD - yes install even stock rom and then flash with 1.7a forget about older 1.7
JustMe
Originally posted by tdcompuservices View Post@JustMeRom
"Box wont turn On after turn OFF via remote control"
1. Press power button on remote control
2. Select Power OFF
>>>>>>>>>>>>Shutting down
3. Box complete shutdown (Power LED is OFF
4. Now press power button on remote control
ISSUE: Box wont turn ONBugs are Sons of Glitches!
JustMe
There are currently 2424 users online. 1 members and 2423 guests.
