New RKM Rom
Have burn this to sd card and booting on my tronsmart draco aw80.
Is there anyway to get the tronsmart remote to work on this.
I can't get into settings to put wifi on so can't use the google remote app,or bluetooth to pair my keyboard with it.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
Minix Neo X8-H (003 FW)
Originally posted by CMJ View PostHave burn this to sd card and booting on my tronsmart draco aw80.
Originally posted by Boxx View Posti will post a fix for you later today.
I copied the sunxi-ir.kl file from the tronsmart system/usr/keylayout and pasted it into the same folder in the mk80 rom.
Remote now works apart from the mouse pointer,i can enable it but it won't move up/down or left/right.
So must have to change something else.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
search for:
Code:ro.softmouse.left.code=7 ro.softmouse.right.code=1 ro.softmouse.top.code=69 ro.softmouse.bottom.code=85 ro.softmouse.leftbtn.code=65
Code:ro.softmouse.left.code=71 ro.softmouse.right.code=21 ro.softmouse.top.code=70 ro.softmouse.bottom.code=22 ro.softmouse.leftbtn.code=85
i´ll add that later today...Last edited by Boxx; 25 March 2015, 13:30.
Originally posted by Boxx View Postto make the mouse pointer work on the draco, edit build.prop.
search for:
Also while I'm thinking about it,is there a way i can back this rom up once i have edited this stuff,so i can use it to restore or reinstall so i don't have to edit it all over again.
Edit
Remote working as it should now apart from not being able to power it on.
Thanks for your help it's much appreciated.Last edited by CMJ; 25 March 2015, 14:48.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
Originally posted by CMJ View PostAlso while I'm thinking about it,is there a way i can back this rom up once i have edited this stuff,so i can use it to restore or reinstall so i don't have to edit it all over again.
1.download dragonface.
2.run DragonFace.exe
3.click on firmware in the upper left corner and select the img file you want to modify. it will take some time to load. ignore the message that pops up after loading is complete.
4.now you can select different tasks(add bootlogo/animation/sound, insert or remove apk´s, change sysconfig, keymapping build.prop...).
5.click on advanced settings>build.prop file, make your changes as shown above, click close and save.
6.for fixing the power on by remote control, click on system configuration and search for: ir rx --- infra remote configuration.
7.scroll down a bit and replace this whole block:
Code:ir_power_key_code = 0x5d ir_addr_code = 0xef10 ;ir_power_key_code = 0x18 ;ir_addr_code = 0xef10 ir_power_key_code0 = 0x5d ir_addr_code0 = 0xef10 ir_power_key_code1 = 0x5d ir_addr_code1 = 0x7F80 ir_power_key_code2 = 0x5d ir_addr_code2 = 0x7F80 ir_power_key_code3 = 0x5d ir_addr_code3 = 0x7F80 ir_power_key_code4 = 0x5d ir_addr_code4 = 0x7F80 ir_power_key_code5 = 0x5d ir_addr_code5 = 0x7F80 ir_power_key_code6 = 0x5d ir_addr_code6 = 0x9F00 ir_power_key_code7 = 0x5d ir_addr_code7 = 0x9F00
Code:ir_power_key_code = 0x18 ir_addr_code = 0xff00 ;ir_power_key_code = 0x18 ;ir_addr_code = 0xff00 ir_power_key_code0 = 0x18 ir_addr_code0 = 0xff00 ir_power_key_code1 = 0x18 ir_addr_code1 = 0x7F80 ir_power_key_code2 = 0x18 ir_addr_code2 = 0x7F80 ir_power_key_code3 = 0x18 ir_addr_code3 = 0x7F80 ir_power_key_code4 = 0x18 ir_addr_code4 = 0x7F80 ir_power_key_code5 = 0x18 ir_addr_code5 = 0x7F80 ir_power_key_code6 = 0x18 ir_addr_code6 = 0x9F00 ir_power_key_code7 = 0x18 ir_addr_code7 = 0x9F00
9.when you are finished modding the firmware, hit save at the bottom of dragonface.
10.your modified rom is ready to burn. if it doesn´t burn as "startup", run it through imgrepacker as described here.
You could also backup with twrp but only the internal memory. you can not backup the sdcard or restore to sdcard.
so i think the method above is the best way to go, especially when you want to install to sd-card.
another way would be to install the rom once to sdcard, insert the card into your computer and then make an image of the whole card with win32 disk imager for example, or dd if you are using linux. this will backup everything, including all your android/app settings.
in the next days, i will add some more information about getting/editing script.bin to my previous post, for people that dont want to go through the whole process and don´t want to reinstall the rom only for replacing the script.bin.
Ricomagic another fail for firmware. Hopefully they come to these forums and start getting user feed back and Dev support.
Ok google apps here's what I know does not work.
Google plus not supported. File manager can't be Uninstalled .update software 3 types and 2 over Lap same type.
Blur line still one inch from bottom and side right side also same. Both in kodi and spmc haven't checked the player.
Connection error for albapp Doesn't work .
Ubuntu? That sucks period no support or way to install apps broken ppa file lists. They really need to start asking Freak tab for assistance from Devs here. I know they talk with Bob from time to time so can't figger out why they are so reluctant? ?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by CMJ View PostRemote fully working thanks,although i still have to move the sunxi-ir.kl file over manually,but maybe I'm just not done something quite right.
Anyway thanks for your help.
sunxi-ir.kl = Buttons
build.prop = mouse pointer
script.bin = power on
Originally posted by Boxx View Postyes, it is necessary to also Change the sunxi-ir.kl as it contains the button mappings.
Thanks.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
boxx i cant remove the file manager. the es file manager yes stock one wont allow the uninstall. anyways tronsmart firmware much better release the video fixed that was my main bitch but still alot of little issue with this release from ricomagic.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2256 users online. 0 members and 2256 guests.
