in my opinion both roms are bad. i will sell my mk80 next month.
New RKM Rom
File exploer and es file explorer and 3 update softwares as i said they over lap each other. it was poor release even video issues not resolved. They going to start coming to freaktab to get user feed back so many here can help them improve these types of releases.
launcher is better ( dont know who picked the colours though yuk lol)Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by CMJ View PostIs there anything i can change so i don't have to move the sunxi-ir.kl manually,or is it the only way.
Thanks.
there is a windows tool called ext4 unpacker but it will only let you view and extract files and it can´t handle most of the other .fex files.Last edited by Boxx; 26 March 2015, 21:22.
Originally posted by Boxx View Posti forgot an important point.
after unpacking the rom, first you have to extract the system.fex, then replace sunxi.ir and pack again as .fex file. this is a linux job, using fex2bin and bin2fex.
there is also a windows vesion but that didn´t work for me.
edit: i think i missed another thing, don´t remember...
I added the sunxi-ir.kl file,also the build prop.
But stuck on repacking it.
Don't have linux only have windows.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
Minix Neo X8-H (003 FW)
Originally posted by CMJ View PostYeah i used that ext4 to unpack the system.fex file.
better watch this video. it explains also how to get the script.bin.
Originally posted by Boxx View Posti think i mixed something up.
better watch this video. it explains also how to get the script.bin.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
Thought I'd update on this i have managed to get it all sorted,used linux in the end installed on virtual box.
So now remote works fully now,i also remove the old xbmc from it,and replaced with kodi 14.2 and a other apps i use.
Thanks for the info Much apappreciated.Tronsmart Draco Telos AW80 (4/32gb) - FW v2.0rc3
Sorry for the late response...
But also sorry, because I read about this problem often/sometimes and don't know any solution to fix it...
RK3288 Devices
- Overview BOX (LINK !)
There are currently 3620 users online. 1 members and 3619 guests.
