Instructions:
First take full phone backup. ADB drivers for your phone must be installed. Then follow these instructions:
- DO NOT CONNECT YOUR TABLET/phone TO PC!
- Run as administrator SP Flash Tool (flash_tool).
- Click scatter file and point the browser to the location of the scatter file. (You will find it inside the folder that mtk droid tools created when you backed up your phone/tablet)
- A list of files will populate your screen with checkboxes all checked, uncheck everything, except the ones that say “EBR1” and “EBR2”.
- The allocation size is defined by the EBR files that you will choose. So, click on the path of the EBR1 and EBR2 lines and select the custom ebr files you downloaded from #2
- Use the “Download Only” setting in the dropdown menu in SP Flash Tool.
- Click the Download button.
- With the tablet/phone powered off, connect the USB.
- Normally your tablet/phone should be recognised and a red progress bar should start filling. Once everything is completed you should see a confirmation dialog. Close the dialog and then the SP Flash Tool.
- Disconnect the USB from your tablet.
- Wait for a minute and power on the tablet. You should now have your new app storage.
When u turn on the tablet you may see a message saying that partition is destroyed or something like that. Don't worry, just select and format the new partition and everything will be ok.
If there is any problem, the procedure is completely reversable, as you can flash back original ebr files.
edit: Some devices require data/cache wipe and then restore defaults from recovery. Do this if after ebr flashing you cannot boot.
edit: 19/7/15 updated attachments
edit: 28/10/15 links from google drive, if local attachments dont work
EBRs for 16GB version
EBRs for 32 GB version
