MK908II Kitkat ROM - Tantrums Mod
    Thank you so much tantrums, you made my day! At last I can set and forget my mk908II in my bedroom setup. The wife is happy!
      I finally found this ROM and it's working very well except for the touch screen and rotation.
      So I am loading this onto my MK908II stick installing Appradio Unchained Reloaded and plugging it into my AppRadio 2. It works very well but when I use the touch screen on the AppRadio 2 (which is in landscape mode) I can see that the stick thinks that it is in Portrait mode. Example: To swipe left or right I have to swipe up and down. I installed RotationLocker to try and force the stick to think it's in landscape mode but no go. Appradio Unchained Reloaded also has an "Invert X/Y coordinates" but that did not seem to help.
      Has anyone else had this problem?
      I tried the other KK ROM on this forum (from VECLINUX) but when I load up Appradio Unchained Reloaded onto stick for setting things up, Google Play Services just keeps crashing every 5 seconds.
      And I'm having trouble down-grading from KK to JB. I've seen the forums indicating the Erasing NAND with KK Flash Tool, and then loading JB with JB Flash Tool (without erasing NAND) but it always fails on Kernel download (Download Image Failed)
      I really don't want to try and short the NAND chip ...
      Any and all help is appreciated.
        Hi
        super #1 your rom
        I have Mk908II with 8gb
        how to make files 8gb_parameter
          Hi thanks for the excellent rom. I'm noticing that this ROM is very stuttery in the animations when opening or closing apps. video playing seems to be fine however. Is there any fix for the animations? I have the MK908II with RK3188 (not T) and AP6210 wifi. I also reduced the DPI to 220 and im using the 720p kernel with 4gb parameter.
          Edit: Fixed using d33's kernel for AP6210 in the RK3188 forums (The forum before you click on MK908 for anyon thats wondering its a sticky thread) Thanks ror the amazing ROM!!!
            Anyone managed to get twrp working with the 908ii
              Alright I've been using this ROM for a few dys with d33's kernel. It is very buggy. I can install adaway and install the hosts file, reboot and then get a bootloop. pls fix
                Is twrp working on this rom? Thank you.
                  Originally posted by tantrums View Post
                  Take note that this ROM can be flashed to all AP6210 models of TV sticks.
                  Hi , it works on mk908 v3 ??
                    Hi, Does this ROM works on MK908 V5 stick???
                      Hello, after installing how can I take a full backup to flash again without loose anything?
                        Hello today ask me to type password to decrypt storage, how to fix it?
                        Στάλθηκε από το JY-F1 μου χρησιμοποιώντας Tapatalk
                          Just installed this on my MK908II with the latest D33 Kernel (HD) - loving it. All the issues I was having on my prior rom (Youtube getting stuck after 30 sec playing, Xposed not fully working, grainy netflix posters, plex experimental player breaking) have been fixed and the rom looks and runs great!
                            Hey everyone,
                            I'm a diehard apple user, and i recently came across the concept of computer dongles, such as the mk908ii. So with that being said, I have no idea what im doing. I recently flashed it with D33's HD Kernel and your ROM. It's running beautifully, no lag no problems, just great sound and picture. Thank you so much! However, using my Rii keyboard and a thrustmaster game controller, i have no idea how to play games downloaded from the playstore or map them to a controller. from what i gathered RKcontroller isnt in the Apple app store? Also, is this the latest version of Android? I apologize for my ignorance with android devices, like i said this is a whole new world for me.
                              Hello!
                              Love the mod, Tantrum...working great on my MK908II! However, I have a touch screen monitor and the multitouch interface isn't currently working. I would like to access the necessary kernel and hid-multitouch files to modify them and get it working. I am learning as I go, and would like to know the best way to get those files from you so I can recompile my own kernel and get the screen completely working.
                              Or...if anyone can help me out with the recompiling themselves, based off of Tantrum's 1080p kernel? I have an Acer UT220hql monitor, Vendor ID is 25aa and Product ID is 8882. (Version is 0110 if that helps.) Listed as a TPV Optical Screen Interface.
                              Any help is appreciated. Thanks!
                                I have the same problem
                                Enviado desde mi C6903 mediante Tapatalk
