MK908II Kitkat ROM - Tantrums Mod
Originally posted by tantrums View PostHi all,
I thought of sharing my personal modded kitkat ROM
- 720p for best performance
- new boot animation
- updated superSU 2.46
- debloated google apps, other apps not necessary and can be downloaded in play store
- added YoutubeTV, Showbox, Reboot and Quick office apps
- "hosts" file to block ads
- very minimal apps
- 26200+ score in Antutu
- 4GB parameter
- others I cannot remember
Hope you like it.
MK908II_442_tantrums_mod.img
Use RKBatchtool
Hello, i try to flash my mk908 device with your personal image, but nothing happens, no blue light when i plug the power.
I need to flash something first? Can you help me?
Hi tantrums, I'm thinking about installing your rom, currently the one I have works pretty well with d33 kernel, but the image is too dark, is this happening as well with your rom? I'm not sure if its an issue with the rom, the kernel or the device itself. I wouldn't like to install everything from scratch again for nothing.
In a normal situation the brightness is ok, but if you are watching a dark scene, the image is too dark, I can barely distinguish whats happening
I'm still downloading RKFlash.zip at the moment. In the meatnime I've downloaded and installed Finless ROM Flash Tool v1.37 and it says "No Found RKAndroid rock usb". I've tried installing drivers manually but I'm running Windows 10...any suggestions? I just want my MK908ii to NOT be a laggy, crashing POS that it is now, so I was hoping flashing Finless 1.7a or the ROM I just found on this thread to make it actually usable.
Originally posted by m5james View PostI'm still downloading RKFlash.zip at the moment. In the meatnime I've downloaded and installed Finless ROM Flash Tool v1.37 and it says "No Found RKAndroid rock usb". I've tried installing drivers manually but I'm running Windows 10...any suggestions? I just want my MK908ii to NOT be a laggy, crashing POS that it is now, so I was hoping flashing Finless 1.7a or the ROM I just found on this thread to make it actually usable.
There are currently 2206 users online. 2 members and 2204 guests.
