The older files and instructions I typically use for Polaroid tablets weren't working for me. So I found a much newer walk through of someone who installed Google Play on the newly released Kindle Fire Hd. Sure enough the files they linked to and their instructions worked for me and my Polaroid PMID10C.
Let's break it down step by step. Here's the info cut and pasted from the link I posted. These are the exact files and instructions I used. It's basically just following them step by step. (I used the "Root Explorer" app for steps 4 and 5.
1. Root your Kindle Fire HD
2. Downloaded and install the GoogleServicesFramework.apk
3. Download Vending.apk
4. Using a file explorer app on the Fire with superuser permissions AND the system file permissions set to Read-Write, move Vending.apk to /system/app.
5. Change the permissions of Vending.apk to User - Read/Write, Group - Read, Others - Read
6. Install Vending.apk
7. The Android Market should show up in your Kindle Fire HD apps. Tap on it and follow the steps.
8. Download and install the Play.apk to upgrade the the android market to the current Play market.
9. Enjoy!
GoogleServicesFramework.apk - mediafire.com/?zaumfwhraxcifqf
Vending.apk - mediafire.com/?31bn3e258jjpj8d
Play.apk - mediafire.com/?wwcqrlfwt8o1gnv
1. Step 1 you skip because the Polaroid 10.1" PMID10C is already "rooted" out of the box.
2. Just like the step says you download and install the "GoogleServices Framework apk file. Download it from the link the original author posted: http://www.mediafire.com/?zaumfwhraxcifqf
You can download to a Micro SD card, or USB flash drive and then transfer the file to your tablet. You could probably also download directly from your tablet if you wanted to using the internet browser. If may give you a warning/ask you if you want to install Google Services framework b/c it's already on the tablet. I just went ahead and installed the downloaded "GoogleServices" apk over the existing file on the tablet. When complete, click "Done".
3. Download the Google "Vending" apk file from: http://www.mediafire.com/?31bn3e258jjpj8d and transfer it to the tablet if you didn't download it there.
4. Here's where it's just a little tricky if you are new to this. You'll need a "special" app to access files with superuser permission to make changes to permissions etc. I use a paid version of the "Root Explorer" app but there are free versions and free alternatives out there. Open the Root Explorer app & navigate to the vending.apk file you downloaded. We need to move the file to the /system/app spot on the tablet.
To do this, while still within "Root Explorer" (or whatever file management app you're using) Long-press Vending.apk & select the "Move" option on pop-up menu. Now navigate to the /system/app folder and tap the "paste" button to paste the vending apk into the /system/app folder.
5. Now we need to set the permissions settings for vending.apk to match the permission settings of the other files in that folder. Long-press Vending.apk & select "Permissions" from pop-up menu. Change permissions to match all other apps in this folder (rw-r--r--). Check the first two boxes on the first line and then the first box on the second and third lines.
6. Install Vending.apk (Just press it and select install)
7. You now have the old Google Market app on your tablet. Go ahead and open it and follow the walk through it gives you to set it up with your existing google account and email address.
8. Now we need to update Google Market to the newer "Google Play". Download the "Play.apk" file to your tablet and install it. (The original author's download link takes you here: http://www.mediafire.com/?wwcqrlfwt8o1gnv)
9. That should be it!
All of the standard disclaimers apply here. This went well for me but I did blindly install files downloaded from an unknown third party.
If you have done something like this before and you follow the steps carefully the odds of messing anything up or permanently bricking your tablet are pretty slim. That being said...I don't think Polaroid/Southern Telecom has released the factory firmware yet. It generally takes them a long time to do so. If you DO manage to mess anything up (unlikely) you'll likely have to wait until they release the firmware to fix your tablet.
Hope that helps!
