Has anyone got ADB drivers to install successfully on Windows 7 64bit? I have the fastboot driver working, but I can't get the ADB driver to install for my 7c G2.
The device is listed in device managers "other devices" as "Arnova 7C G2" five times, but I can't find a driver that works with adb.
I have tried forcing the google "adb composite device" to each of the 5 devices in device manager but it still doesn't work
Yes I did. It was a major PAIN. I had to force install. I do not remember the exact steps now butw hen you go to do it choose let me pick (chose "other" device or something like that) and then have disk and browse to the driver.
I installed the adb driver for my arnova 7 G2 and it is now listed as "android composite adb interface". But when i do "adb devices" I see an empty list. I'm on windows 7 64bit. Am I missing something?
Not sure which driver you loaded? I used the generic one from google.
In the device manager I have:
Android Phone
|_ Android ADB Interface
I am on Win 7 64
Also you need to let ADB know your device. Do this
create a file: adb_usb.ini in the following directory:
Windows 7: C:\Users\<user>\.android
Enter following code in the ini file:
0x0e79
You should be able now to execute:
adb start-server
The Google USB Driver is required to perform adb debugging on Windows with Google devices.
