Ematic 7" Pro series EGP007BL
Update: 12/4/12 6:51pm
Cheers folks,
Rainer and I did a TeamView session and walked over the steps to see where the hang up is. It appears the issue is with the device driver itself and not the ID that's causing the hangup.
Tricky little tablet. But from what I can tell, it has a lot of interesting dev options that most of the bigger name tablets don't have.
We are going to pick back up on this tomorrow and see what else we can figure out. Being on different sides of the world makes for some time constraints.
In the meantime, I've had a little bit of luck with the tmobile marketplace installed on mine. I was able to get kindle and nook apps to work. A few of the more basic games as well. The soc.io mall is worthless, as is KOBU. I've also heard a rumor that the older version of amazon's app market working on these, so I'll give that a shot while Rainer works his driver magic.
We'll be sure to keep you updated on the progress.
-Brian-"When the going gets weird, the weird turn pro."
-Hunter Stockton Thompson
Cheers folks,
Other Work Arounds that do not work
Hello all,
Here a few things I have done so far to try and get the Ematic Pro Series egp007 to load the android market successfully that haven't worked. I'm writing this so you don't waste your time.
1. I have tried to root tablet using the Android SDK tools and SuperOneClick though USB connection to my PC (http://forum.xda-developers.com/show....php?t=1673080) but that bombs because of the driver issue we are seeing from earlier in this thread.
2. I have tried the instructions from http://www.androidtablets.net/forum/...xl-tablet.html
Doesn't work. you'll get to signing into the Android Market and then it stops responding. This will happen everytime you open the market. I've tried different versions of framework and market apks and still doesn't work.
3.Tried this one too: http://www.computric.com/2012/04/ins...thout-rooting/
still doesn't work
Another interesting note is that some of the items these people wanted you to install onto the tablet first before installing the market were already installed on the tablet by default. Such as onetimeinitializer-signed.apk and Googleservicesframework.apk
Has anybody else had any luck with this tablet getting the Android market to work while we wait for a ROM to come through to save the day?
Hardware INfo
Unknown rk29sdk - EGP007
-System-
Firmware 4.0.4
SDK 15
Display
Size 800x444
Logical Density 0.75
Front Scaling Factor 0.75
Pixels Per Inch X 131.94806
Pixels Per Inch Y 143.43529
-Camera-
Picture Size Values 176x144, 240x160, 320x240, 352x288, 640x480, 640x480,320x240
Zoom 0
Preview Fps Range 3000, 30000
Min Exposure Compensation 0
Recording Hint false
Max Num Detected Faces Hw 0
Vertical View Angle 100
Zoom Supported true
Horizontal View Angle 100
White Balance auto
Video Stabilization Supported false
Jpeg Thumbnail Height 128
Scene Mode auto
Jpeg Quality 70
Preview Format Values yuv420sp, rgb565, yuv420p
Rotation 0
Jpeg Thumbnail Quality 50
Focus Mode fixed
Preview Format yuv420sp
Preview Size 640x480
Focal Length 35
Video Frame Format yuv420sp
Max Num Detected Faces Sw 0
Picture Format Values jpeg
Max Exposure Compensation 0
Video Snapshot Supported true
Flash Mode Values off, auto, on, torch
Preview Frame Rate Values 8
Exposure Compensation Step 0.000001f
Max Num Metering Areas 0
Preview Frame Rate 8
Flash Mode off
Effect Values none, mono, negative, sepia, postersize, aqua
Focus Mode Values fixed
Picture Size 640x480
Max Zoom 20
Effect none
Jpeg Thumbnail Width 160
Whitebalance Values auto, incandescent, flourescent, daylight, cloudy-daylight
Scene Mode Values auto, night
Picture Format jpeg
Focus Distances 0.3, 50, Infinity
Preview Fps Range Values (3000, 30000)
Jpeg Thumbnail Size Values 0x0, 160x128
Zoom Ratios 100, 105, 110, 115, 120, 125, 130, 135, 140, 145, 150, 155, 160, 165, 170, 175, 180, 185, 190, 195, 200
Preview Size Values 176x144, 240x160, 320x240, 352x288, 640x480
-Graphics-
Renderer GC800 Graphics Engine
Version OpenGL ES-CM 1.1
Vendor Vivante Corporation
Max Texture Size 8192
Max Texture Units 4
Extensions GL_OES_mappbuffer GL_OES_query_matrix GL_OES_matrix_get GL_OES_draw_texture GL_OES_matrix_palette GL_ARB_vertex_buffer_object GL_VIV_direct_texture ARB_multitexture
GL_EXT_texture_compression_dxt1 GL_EXT_texture_format_BGRA8888 GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image GL_OES_vertex_half_float
GL_OES_framebuffer_object GL_OES_texture_Cube_map GL_OES_EGL_image_external GL_OES_EXT_multi_draw_arrays GL_OES_rgb8_rgba8 GL_ARB_texture_non_power_of_two
GL_ANDROID_direct_texture
-Sensors-
MMA8452Q 3-Axis Accelerometer
Vendor Freescale Semiconductor
Range 39.24
Resolution 0.15328126
Power 0.2mA
AK8975 3-axis Magnetic field sensor
Vendor Asahi Kasei
Range 2000.0
Resolution 0.0625
Power 6.8mA
AK8975 Orientation sensor
Vendor Asahi Kasei
Range 360.0
Resolution 1.0
Power 7.0mA
AL3006Proximity sensor
Vendor Dyna Image Corporation
Range 9.0
Resolution 9.0
Power 0.5mA
AL3006 light sensor
Range 10240.0
Resolution 1.0
Power 0.5mA
That's all I got from the tool
There are currently 2942 users online. 1 members and 2941 guests.
