Hi guys,
based on the stock 720p kernel.img from Finless 1.5A ROM http://www.freaktab.com/showthread.p...-5A-Custom-ROM, I created a patched kernel.img (see attached) that ONLY differs from the stock 720p in the 16 bytes that were necessary (+some credits) to turn the 720p into an 1080p firmware, NOTHING ELSE WAS CHANGED!
The patch is limited to the changes that enable 1080p that without tampering anything else... (Using AndrewDB's kernel sources, I diffed the disassembled 720p+1080p object files to see what is the changeset, disassembled the stock 720p kernel, searched for the right context of the changeset and injected the changes)
HOW TO:
- Use Finless 1.5A ROM, but flash the attached kernel.img instead of the kernel.img that is shipped with Finless.
- If you already have Finless 1.5A running, you can just flash the kernel.img (only tick kernel in the flash tool!).
- Your device will boot into 1080p mode. You can verify this with screeinfo.
- YOU MAY ALSO NEED TO CHANGE the HDMI mode in android settings to 1080p!
- !!!FLASH AT YOUR OWN RISK!!!
You will see an ugly looking splash screen while boot because the splash screen is for 720p...
DOWNLOAD: https://docs.google.com/open?id=0B0O...GJnNzRtWXZHSFE
PLEASE NOTE: I cannot tell you WHICH of the community-based 1080p kernels is the best one. My premise was to do only minimal-invasive changes to the stock kernel that is supplied with Finless 1.5A, as this runs pretty rock solid for me (Wifi etc.) and was only lacking 1080p. The other community kernels are afaik built completely from the "leaked" kernel sources and *MAY* carry more (unwanted) differences to the stock kernel.
dero
