1080p patch for NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
720p 1080p
what is the difference in performance between finless 1.5A with its attached kernel and finless 1.5A with kizs 720P kernel? any major improvement?
what is the resolution delivered when you choose 1920X1080 with fineless or kizs 720P kernel?how does it differ with the 1920X1080 with a 1080P kernel?
thank you for the info!!
wifi don't work
I have a big problem and I can not do at all. I have an android mini TV for A9 dual core android I installed 1.5a ROM Root mk808 Finless which works perfectly except wifi. Viewing maximum signal but can not connect. I have a router HUAWEI HG 520b. What should I do I can have wifi internet? Thanks
There are currently 2698 users online. 2 members and 2696 guests.
