[ROM] PMID4311 / EM543 - CM10, CWM, Root, PlayStore
Originally posted by bbsux View Postjust flashed my emerson with your new version and still don't have touchscreen
To identify the cause, I need the output from dmesg. Please reboot, then as soon as the homescreen appears, run this "adb shell dmesg > dmesg.txt" then send it to me in a private message.
Of course this assumes you have ADB set up. If not, open the Terminal app, run "su", then "dmesg > /sdcard/dmesg.txt" or "dmesg > /sdcard_external/dmesg.txt". Pull the file over to your PC using USB storage, then attach it to a pm.
i tried to send you a pm of dmesg but its to long for pm i had never did this before but i do have adb setup on my pc so i tried
ddr_buf: 0x38. dirty_addr_buf[1]: 0xfffe
<6>[ 13.590000] ctp_fetch_sysconfig_para: ctp_twi_id is 1.
<6>[ 13.590000] ctp_fetch_sysconfig_para: screen_max_x = 480.
<6>[ 13.640000] ctp_fetch_sysconfig_para: screen_max_y = 272.
<6>[ 13.640000] ctp_fetch_sysconfig_para: revert_x_flag = 0.
<6>[ 13.680000] ctp_fetch_sysconfig_para: revert_y_flag = 0.
<6>[ 13.760000] ctp_fetch_sysconfig_para: exchange_x_y_flag = 0.
<6>[ 13.760000] ft5x_ts_init: after fetch_sysconfig_para: normal_i2c: 0x38. n
ormal_i2c[1]: 0xfffe
<4>[ 13.830000] script parser fetch err.
<4>[ 13.830000] ctp_init_platform_resource: tp_reset request gpio fail!
<6>[ 13.860000] ctp_wakeup.
<6>[ 14.000000] ctp_detect: Detected chip ft5x_ts at adapter 1, address 0x38
<6>[ 14.020000] ====ft5x_ts_probe begin=====.
<6>[ 14.020000] msg ft5x_i2c_rxdata i2c read error: -70
<4>[ 14.030000] ft5x_ts not detect.
<6>[ 14.030000] ==singlethread error =
<4>[ 14.030000] ft5x_ts: probe of 1-0038 failed with error -70
<6>[ 14.050000] init: command 'insmod' r=0
<3>[ 14.080000] =========Novatek_TouchDriver============
<4>[ 14.100000] ctp_is_used =0
<3>[ 14.100000] VERSION =1.0
<3>[ 14.100000] NT1100x_ts_init: script_parser_fetch err.
<6>[ 14.170000] init: command 'insmod' r=-1
<4>[ 14.220000] ===========================goodix_ts_init========= ============
<4>[ 14.220000] ctp_is_used =0
<4>[ 14.280000] ctp_fetch_sysconfig_para.
<3>[ 14.280000] ctp_fetch_sysconfig_para: script_parser_fetch err.
<5>[ 14.280000] =========script_parser_fetch_err============
<4>[ 14.320000] goodix_ts_init: err.
<6>[ 14.320000] init: command 'insmod' r=-1
<6>[ 14.330000] ================================================
<4>[ 14.350000] ctp_is_used =0
<6>[ 14.350000] ctp_fetch_sysconfig_para.
<3>[ 14.350000] ctp_fetch_sysconfig_para: name ft5x_ts does not match CTP_NAME
<3>[ 14.370000] ldwzic
<6>[ 14.370000] ldwzic_ts_init: err.
<6>[ 14.370000] init: command 'insmod' r=-1
<4>[ 14.480000] ===========================goodix_ts_init========= ============
<4>[ 14.480000] ctp_is_used =0
<4>[ 14.490000] ctp_fetch_sysconfig_para.
<3>[ 14.490000] ctp_fetch_sysconfig_para: script_parser_fetch err.
<5>[ 14.510000] =========script_parser_fetch_err============
<4>[ 14.510000] goodix_ts_init: err.
<6>[ 14.520000] init: command 'insmod' r=-1
<4>[ 14.580000] ctp_is_used =0
<4>[ 14.580000] rtp_used == 1.
<4>[ 14.580000] sun4i-ts: tp_screen_size is 5 inch.
<4>[ 14.610000] sun4i-ts: tp_regidity_level is 5.
<4>[ 14.610000] sun4i-ts: tp_press_threshold_enable is 0.
<4>[ 14.630000] sun4i-ts: rtp_sensitive_level is 15.
<4>[ 14.630000] sun4i-ts: rtp_revert_y_flag is 1.
<4>[ 14.630000] sun4i-ts: rtp_exchange_x_y_flag is 0.
<6>[ 14.650000] input: sun4i-ts as /devices/platform/sun4i-ts/input/input2
<4>[ 14.650000] ==register_early_suspend =
<6>[ 14.670000] init: command 'insmod' r=0
<6>[ 14.720000] init: command 'insmod' r=0
<6>[ 14.740000] init: command 'insmod' r=0
<6>[ 14.750000] init: command 'insmod' r=0
<6>[ 14.770000] init: command 'insmod' r=0
<6>[ 14.800000] init: command 'insmod' r=0
<6>[ 14.830000] [CSI]Welcome to CSI driver
<6>[ 14.830000] [CSI]csi_init
<6>[ 14.840000] [CSI]registered sub device,input_num = 0
<6>[ 14.850000] [CSI]power on and power off camera!
<6>[ 15.000000] [CSI]V4L2 device registered as video0
<6>[ 15.010000] init: command 'insmod' r=0
<6>[ 15.030000] init: command 'insmod' r=0
<6>[ 15.100000] usbcore: registered new interface driver asix
<6>[ 15.130000] init: command 'insmod' r=0
<6>[ 15.180000] usbcore: registered new interface driver qf9700
<6>[ 15.180000] init: command 'insmod' r=0
<6>[ 15.200000] usbcore: registered new interface driver MOSCHIP usb-ethernet
driver
<6>[ 15.210000] init: command 'insmod' r=0
<6>[ 15.230000] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
<6>[ 15.240000] usbcore: registered new interface driver rtl8150
<6>[ 15.250000] init: command 'insmod' r=0
<6>[ 15.250000] init: command 'insmod' r=-1
<5>[ 15.260000] init: starting 'bootanim'
<4>[ 15.340000] ======mma7660_init=========.
<4>[ 15.350000] ========gsensor_fetch_sysconfig_para============== =====
<4>[ 15.350000] gsensor_fetch_sysconfig_para: after: gsensor_twi_addr is 0x4c,
dirty_addr_buf: 0x4c. dirty_addr_buf[1]: 0xfffe
<4>[ 15.370000] gsensor_fetch_sysconfig_para: twi_id is 1.
<4>[ 15.380000] mma7660_init: after fetch_sysconfig_para: normal_i2c: 0x4c. n
<6>[ 15.380000] gsensor_detect: Detected chip mma7660 at adapter 1, address 0x
4c
<6>[ 15.390000] mma7660 probe
<6>[ 15.770000] mma7660 1-004c: build time Jun 20 2012 19:12:09
<6>[ 15.780000] input: mma7660 as /devices/virtual/input/input3
<6>[ 15.780000] add mma7660 i2c driver
<6>[ 15.790000] init: command 'insmod' r=0
<6>[ 15.790000] init: processing action 0x1c234b8 (queue_property_triggers)
<6>[ 15.800000] init: command 'queue_property_triggers' r=0
<6>[ 15.800000] init: processing action 0x1c1c2d8 (property:ro.debuggable=1)
<5>[ 15.810000] init: starting 'console'
<6>[ 15.810000] init: command 'start' r=0
<6>[ 15.820000] init: processing action 0x1c221c8 (propertyersist.sys.usb.co
nfig=*)
<6>[ 15.830000] init: command 'setprop' r=0
<6>[ 15.840000] init: processing action 0x1c22220 (property:service.adb.root=1
<3>[ 15.840000] android_usb: already disabled
<6>[ 15.850000] init: command 'write' r=0
<5>[ 15.850000] init: starting 'adbd'
<6>[ 15.860000] adb_open
<6>[ 15.860000] init: command 'restart' r=0
<4>[ 15.860000] [sw_udc]: sw_udc_pullup, is_on = 1
<4>[ 15.870000] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED
<4>[ 15.870000] [sw_udc]: usbd_start_work
<6>[ 15.880000] init: command 'write' r=0
<6>[ 15.880000] init: processing action 0x1c225e8 (property:sys.usb.config=mas
s_storage,adb)
<4>[ 15.890000] [sw_udc]: sw_udc_pullup, is_on = 0
<4>[ 15.890000] [sw_udc]: usbd_stop_work
<6>[ 15.900000] init: command 'write' r=0
<6>[ 15.910000] init: command 'write' r=0
<4>[ 15.910000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5f30, 0xdf
b33200, ep1-bulk)
<6>[ 15.920000] adb_bind_config
<4>[ 15.920000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5f30, 0xdf
b33200, ep1-bulk)
<4>[ 15.930000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5f70, 0xdf
b33200, ep2-bulk)
<4>[ 15.940000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5f30, 0xdf
b33200, ep1-bulk)
<4>[ 15.950000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5f70, 0xdf
b33200, ep2-bulk)
<4>[ 15.960000] ep_matches, wrn: endpoint already claimed, ep(0xc08c5fb0, 0xdf
b30000, ep3-bulk)
<4>[ 15.970000] [sw_udc]: alloc request: ep(0xc08c5ff0, ep4-bulk, 512), req(0x
dd0019c0)
<4>[ 15.970000] [sw_udc]: alloc request: ep(0xc08c5fb0, ep3-bulk, 512), req(0x
dd001a00)
<4>[ 15.980000] [sw_udc]: alloc request: ep(0xc08c5fb0, ep3-bulk, 512), req(0x
dd001a40)
<4>[ 15.990000] [sw_udc]: alloc request: ep(0xc08c5fb0, ep3-bulk, 512), req(0x
dd001a80)
<4>[ 16.000000] [sw_udc]: alloc request: ep(0xc08c5fb0, ep3-bulk, 512), req(0x
dd001ac0)
<4>[ 16.000000] [sw_udc]: sw_udc_pullup, is_on = 1
<4>[ 16.010000] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED
<4>[ 16.010000] [sw_udc]: usbd_start_work
<6>[ 16.020000] init: command 'write' r=0
<6>[ 16.020000] init: command 'start' r=0
<6>[ 16.020000] init: command 'setprop' r=0
<4>[ 16.070000] [sw_udc]: IRQ: suspend
<4>[ 16.070000] [sw_udc]: ERR: usb speed is unkown
<4>[ 16.260000] [sw_udc]: IRQ: reset
<4>[ 16.260000] [sw_udc]: irq: reset happen, throw away all urb
<4>[ 16.450000] [sw_udc]:
<4>[ 16.450000] +++++++++++++++++++++++++++++++++++++
<4>[ 16.450000] [sw_udc]: usb enter high speed.
<4>[ 16.470000] [sw_udc]: IRQ: reset
<4>[ 16.470000] [sw_udc]: irq: reset happen, throw away all urb
<6>[ 16.530000] android_work: sent uevent USB_STATE=CONNECTED
<4>[ 16.650000] [sw_udc]: Set address 1
<6>[ 16.860000] android_usb gadget: high speed config #1: android
<4>[ 16.860000] [sw_udc]: ep enable: ep(0xc08c5fb0, ep3-bulk, 128, 512)
<4>[ 16.860000] [sw_udc]: ep enable: ep(0xc08c5ff0, ep4-bulk, 0, 512)
<4>[ 16.880000] [sw_udc]: ep enable: ep(0xc08c5f30, ep1-bulk, 128, 512)
<6>[ 16.890000] android_work: sent uevent USB_STATE=CONFIGURED
<4>[ 16.910000] ep enable: ep(0xc08c5f70, ep2-bulk, 0, 512)
<4>[ 16.910000] [sw_udc]: alloc request: ep(0xc08c5f30, ep1-bulk, 512), req(0x
dd0ce980)
<4>[ 16.930000] [sw_udc]: alloc request: ep(0xc08c5f70, ep2-bulk, 512), req(0x
dd0ceac0)
<4>[ 16.960000] [sw_udc]: alloc request: ep(0xc08c5f30, ep1-bulk, 512), req(0x
dd0ce9c0)
<4>[ 16.960000] [sw_udc]: alloc request: ep(0xc08c5f70, ep2-bulk, 512), req(0x
dd0cea40)
<4>[ 21.890000] WRN:L1361(drivers/usb/sun5i_usb/udc/sw_udc.c):handle_ep0: ep0
setup end
<4>[ 40.760000] sw_usb_enable_hcd: usbc_num = 1
<4>[ 40.760000] [sw-ehci1]: sw_usb_enable_ehci
<4>[ 40.780000] [sw-ehci1]: probe, pdev->name: sw-ehci, pdev->id: 1, sw_ehci:
0xc0995324
<4>[ 40.780000] [sw-ehci1]: open clock
<4>[ 40.860000] usb_passby en=1,passly=0
<4>[ 40.860000] hci_port_configure en=1,config_cnt=0
<4>[ 40.890000] [sw-ehci1]: Set USB Power ON
<6>[ 40.900000] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI)
Driver
<6>[ 40.900000] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number
2
<6>[ 40.910000] sw-ehci sw-ehci.1: irq 39, io mem 0xf1c14000
<6>[ 40.950000] sw-ehci sw-ehci.1: USB 0.0 started, EHCI 1.00
<4>[ 40.950000] ehci_irq: port change detect
<6>[ 41.000000] hub 2-0:1.0: USB hub found
<6>[ 41.000000] hub 2-0:1.0: 1 port detected
<4>[ 41.010000] [sw-ohci1]: sw_usb_enable_ohci
<4>[ 41.010000] [sw-ohci1]: probe, pdev->name: sw-ohci, pdev->id: 1, sw_ohci:
0xc0995438
<4>[ 41.020000] [sw-ohci1]: open clock
<6>[ 41.080000] acc_open
<6>[ 41.080000] acc_release
<4>[ 41.100000] hci_port_configure en=1,config_cnt=1
<4>[ 41.110000] usb_passby en=1,passly=1
<6>[ 41.110000] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Dri
ver
<6>[ 41.120000] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number
3
<6>[ 41.130000] sw-ohci sw-ohci.1: irq 40, io mem 0xf1c14400
<6>[ 41.200000] hub 3-0:1.0: USB hub found
<6>[ 41.200000] hub 3-0:1.0: 1 port detected
<4>[ 41.220000] rtw driver version=v3.4.2_3727.20120404
<4>[ 41.220000] Build at: Jun 20 2012 19:14:51
<4>[ 41.230000] ##########rtw_suspend_lock_init ###########
<6>[ 41.240000] usbcore: registered new interface driver rtl8192cu
<5>[ 41.320000] init: starting 'wpa_supplicant'
<6>[ 41.330000] usb 2-1: new high speed USB device number 2 using sw-ehci
<6>[ 41.350000] init: Created socket '/dev/socket/wpa_wlan0' with mode '660',
user '1010', group '1010'
<4>[ 41.480000] register rtw_netdev_ops to netdev_ops
<4>[ 41.480000] rtw_wdev_alloc
<4>[ 41.520000] CHIP TYPE: RTL8188C_8192C
<4>[ 41.520000]
<4>[ 41.520000] usb_endpoint_descriptor(0):
<4>[ 41.520000] bLength=7
<4>[ 41.590000] bDescriptorType=5
<4>[ 41.590000] bEndpointAddress=81
<4>[ 41.590000] wMaxPacketSize=200
<4>[ 41.590000] bInterval=0
<4>[ 41.650000] RT_usb_endpoint_is_bulk_in = 1
<4>[ 41.650000]
<4>[ 41.650000] usb_endpoint_descriptor(1):
<4>[ 41.710000] bLength=7
<4>[ 41.710000] bDescriptorType=5
<4>[ 41.710000] bEndpointAddress=2
<4>[ 41.720000] wMaxPacketSize=200
<4>[ 41.720000] bInterval=0
<4>[ 41.720000] RT_usb_endpoint_is_bulk_out = 2
<4>[ 41.720000]
<4>[ 41.720000] usb_endpoint_descriptor(2):
<4>[ 41.800000] bLength=7
<4>[ 41.800000] bDescriptorType=5
<4>[ 41.800000] bEndpointAddress=3
<4>[ 41.800000] wMaxPacketSize=200
<4>[ 41.870000] bInterval=0
<4>[ 41.870000] RT_usb_endpoint_is_bulk_out = 3
<4>[ 41.880000]
<4>[ 41.880000] usb_endpoint_descriptor(3):
<4>[ 41.880000] bLength=7
<4>[ 41.880000] bDescriptorType=5
<6>[ 41.920000] init: waitpid returned pid 371, status = 0000ff00
<5>[ 41.930000] init: process 'wpa_supplicant', pid 371 exited
<4>[ 41.930000] bEndpointAddress=84
<4>[ 42.000000] wMaxPacketSize=40
<4>[ 42.000000] bInterval=1
<4>[ 42.000000] RT_usb_endpoint_is_int_in = 4, Interval = 1
<4>[ 42.010000] nr_endpoint=4, in_num=2, out_num=2
<4>[ 42.010000]
<4>[ 42.040000] USB_SPEED_HIGH
<4>[ 42.040000] Chip Version ID: VERSION_NORMAL_UMC_CHIP_88C_B_CUT.
<4>[ 42.100000] RF_Type is 3!!
<4>[ 42.110000] EEPROM type is E-FUSE
<4>[ 42.110000] ====> ReadAdapterInfo8192C
<4>[ 42.110000] Boot from EFUSE, Autoload OK !
<4>[ 42.590000] EEPROMVID = 0x0bda
<4>[ 42.610000] EEPROMPID = 0x8176
<4>[ 42.610000] EEPROMCustomerID : 0x00
<4>[ 42.620000] EEPROMSubCustomerID: 0x00
<4>[ 42.620000] RT_CustomerID: 0x00
<4>[ 42.620000] _ReadMACAddress MAC Address from EFUSE = 00:44:eb:46:c7:8b
<4>[ 42.630000] EEPROMRegulatory = 0x0
<4>[ 42.630000] _ReadBoardType(0)
<4>[ 42.660000] BT Coexistance = disable
<4>[ 42.690000] RT_ChannelPlan: 0x0a
<4>[ 42.690000] _ReadPSSetting...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportR
emoteWakeup(0)
<4>[ 42.700000] ### PS params=> power_mgnt(1),usbss_enable(0) ###
<4>[ 42.700000] ### AntDivCfg(0)
<4>[ 42.820000] readAdapterInfo_8192CU(): REPLACEMENT = 1
<4>[ 42.820000] <==== ReadAdapterInfo8192C in 710 ms
<4>[ 42.910000] rtw_register_early_suspend
<4>[ 42.910000] rtw_macaddr_cfg MAC Address = 00:44:eb:46:c7:8b
<4>[ 43.060000] MAC Address from pnetdev->dev_addr= 00:44:eb:46:c7:8b
<4>[ 43.070000] bDriverStopped:1, bSurpriseRemoved:0, bup:0, hw_init_completed
:0
<6>[ 44.650000] init: waitpid returned pid 380, status = 00000000
<3>[ 44.650000] init: untracked pid 380 exited
<3>[ 51.010000] init: sys_prop: permission denied uid:1003 name:service.boota
nim.exit
<6>[ 51.050000] init: waitpid returned pid 256, status = 00000000
<5>[ 51.060000] init: process 'bootanim', pid 256 exited
C:\Users\james>
touch screen
just thinking if the rom is the problem then way when i flash the factory one do i still have no touch screen or wifi and camera .my problem started when i tried this and it didnt
install because of a problem with how 7 zip opened the download thats why it worked on the other pc then i flashed the stock rom thats when my problem started
Originally posted by rusty2788 View Postjust thinking if the rom is the problem then way when i flash the factory one do i still have no touch screen or wifi and camera .my problem started when i tried this and it didnt
Originally posted by Spidengo View PostDoh, I just re-read forums. You are not the person with the bad unit. It's Sunday, I'm lazy reading I guess.
I just don't know why the factory image doesn't fix it unless it is just a bad unit.I know these thing are just cheap and not worth alot
Feedback of CWM (10 partitions) update - Polaroid PMID4311
Originally posted by dolorespark View PostFor those who don't want to try this ROM but would like an updated version of CWM, you can use "4311-cwm-10partitions.zip", also at the URL above
It has a problem with making backups. I'm using the stock ICS ATM and the process hung somewhere near the end. I had to power off and then when trying to do a restore, I got the error of a MD5 mismatch.
During the factory reset option, it mentioned that there wasn't an app2sd partition. The message showed that it was "skipping format of /sd-ext". Isn't the external sd at /mnt/extsd?
Trying to install William Kleiman's CM9 zip resulted in a "(bad) Installation aborted" message. Though could be just a version difference there.
I tried installing the SuperSU recovery zip file and the recovery did its thing until "Update Complete!", but I can't find a reference to it on the system. "su" via terminal went straight to "#" and adaway didn't ask for permission... strange. I also noticed that all of those recovery.img files and even some fragments of busybox were still lurking in the file system. Didn't I just wipe that during the factory reset?
I really appreciate what you are doing and hope that my tests are helpful.
Originally posted by bbsux View Postheres the file you cant send files via pms
Originally posted by rusty2788 View Posti had never did this before but i do have adb setup on my pc so i tried
--- snip ---
Could you try again and post the entries timestamped 13.xxxx and 14xxx?
Originally posted by alienedd View PostIt has a problem with making backups. I'm using the stock ICS ATM and the process hung somewhere near the end. I had to power off and then when trying to do a restore, I got the error of a MD5 mismatch.
There are currently 2106 users online. 1 members and 2105 guests.
