[ROM] PMID4311 / EM543 - CM10, CWM, Root, PlayStore
Originally posted by bbsux View PostI think my emerson is bricked. I tried to flash it to stock, livesuite gave an image error and now the tablet just sits there...
so what you need is a dmesg from a stock Emerson?
At this point, I'm starting to wonder if the real problem lies with S.T.'s firmware update rather than the tablets. In the bootloader partition, there's a file (script.bin) that the system uses to configure itself. Among other things, it identifies two possible touchscreen controller chips and the drivers they use. The files from both the 4311 and the 543 update say they use either gt811.ko or ft5x_ts.ko. However, whoever pulled the 543 apart said that it had a Sitronix 1530 controller which uses sichuang.ko. If script.bin provides the info needed to identify a chip and load its driver, then you'll never get your touchscreen back using either my ROM or the stock ROM. If I could get a virgin copy of script.bin, I could confirm my suspicions - and maybe fix the problem.
Any volunteers?
Originally posted by fussybutt View PostI should have read through the entire thread before trying it, but it's too late now. If you don't find a fix by tomorrow afternoon, I'll take it back to Big Lots and swap it out for another one.
Originally posted by bbsux View PostI am the one that took it apart and the sitronix is in there, at least in mine.
Can you pull that from a image?
I wish I could just go buy a couple from big lots so I had a few more of these. Mine is out.
P.S. were you the person who also has the Polaroid version? If so, has this ROM given you any problems on the 4311?
Originally posted by dolorespark View PostAnd you're absolutely, positively, 100% sure there isn't any Goodix chip in there?
Originally posted by dolorespark View PostI have to look at the original bootloader image to see if script.bin mentions the sitronix driver. The bootloader in ST's update is identical to the 4311's which is why I thought they'd be 100% compatible. In fact, even the update's name implies it's using a gt811. Embedded in the file name is "kf006" - this is the "machine name" parameter passed to the gt811 driver and appears nowhere else.
The local stores have so many Polaroids and Emersons they can't give them away. The Polaroid is down to $40 while the Emerson is $50. I plan to get an Emerson tomorrow (if no one offers a stock script.bin) and before I do anything else, I'm going to archive each partition.
Yeah I have both, the polaroid seems ok on the new rom.
I don't suppose you could buy me two polaroid units and I could Paypal you the $ plus shipping? All the stores out here have no 4.3" units at all.
Originally posted by dolorespark View PostI don't doubt that you've lost your touchscreen but "bricked"? How so? (I assume you have the Emerson, correct?)
Originally posted by Magister View PostFYI, my touchscreen come from Hotatouch, I think model is DRFPC058T-V2.0
Before "bricking" my unit and trying a reflash, I got the time to so a ls -alR, here's what into a sitronix_httu folder, if it can help
./sitronix_httu:
-rwxrwxrwx root root 15104 1969-12-31 19:00 ATUNE_ST1536_A8002C_2143_ANS4.bin
-rwxrwxrwx root root 15872 1969-12-31 19:00 CSTOUCH_N_ST1536_A8002C_7643_A10_ANS4.bin
lrwxrwxrwx root root 2012-11-26 09:31 FC_CheckSum -> /data/httu/FC_CheckSum
-rwxrwxrwx root root 512 1969-12-31 19:00 FwConfig_Topwise43_7643.bin
-rwxrwxrwx root root 716240 1969-12-31 19:00 HTTU103E
-rw-rw-rw- root root 2 2012-11-26 09:31 HttuFinish.txt
-rwxrwxrwx root root 512 1969-12-31 19:00 TEST_ATN_0808_7643_Border.ATN
-rw-rw-rw- root root 354 2012-11-26 09:31 UpgradeLog.txt
-rwxrwxrwx root root 965 1969-12-31 19:00 sitronix.sh
-rwxrwxrwx root root 357378 1969-12-31 19:00 sitronix_httu.zip
Originally posted by Magister View PostBefore "bricking" my unit and trying a reflash, I got the time to so a ls -alR, here's what into a sitronix_httu folder
Originally posted by dolorespark View PostAny volunteers?
Being a hardware hacker, I'd also love to see about testing the usb port for host capabilities, test usb bluetooth module compatibility, and wiring one inside. Maybe improving the battery as well.
There are currently 2917 users online. 1 members and 2916 guests.
