http://adf.ly/G2smd
Download in movie discription on youtube and on my website
http://adf.ly/G78Xk. Have fun
-Unpack playercorefactory.xml, for MX Player Pro or the one for Mx Player free.
-Transfer the files over to your device.
-Install XBMC.apk through a file manager.
-If you want to play movies from NAS/FTP you need to install cifs manager and mount your shares as internal disks, after that go to XBMC click on Video>Add Source>Root File System>mnt> and choos your HDD.
-Return to the file manager and Copy playercorefactory.xml and advancedsettings.xml. Navigate to Android/data/org.xbmc.xbmc/files/.xbmc/userdata and copy PlayerCoreFactory.XML there.
-If you want Xperience skin for XBMC just install System>Add-ons>Install from zip file>External storage>repository.blacks and then go to System>Add-ons>Blacks Repo>Skin>Xperience1080.
-If ou want dts sound extract the files from the mx_dt_scodec.rar and copy them to your device Sdcard then, in MX Player, Go to Settings -> Decoder, scroll all the way to the bottom, and tap Custom codec.
Then, select the folder containing the codec files you copied over and tap OK. MX Player will then close, and after you restart it you should be ok.
Lewy20041
