XBMC Frodo Beta2 Neon Android 1080p HW + DTS MK808 (How To and Download)
Originally posted by lewy20041 View Postin xbmc video did you added path to /mnt/cifs. mx wil not work with network shares until they are mounted as internal.
try pressing "c" on your keyboard and select play movie with or some similar i dont remember for sure. then secect mp player and post back if it worked for you
I never had this problem on earlier versions of NEON XBMC builds, it would always play using MX player every time
I have tried to select a different player (while mouse pointer is over a movie) by pressing the 'c' (contextual menu) key on my keyboard but the option for selecting another player is not there, (it is on my PC,Xbox xbmc) all I see is:
Queue item
Play from here
Add to favourites
Movie Information
Mark as watched
Link to TV show
Update library
EDIT: Just noticed my 'playercorefactory.xml is 0Kb in size, looks like it didn't download correctly, going to download it again and retryLast edited by no1john; 08 December 2012, 15:27.
Got it working at last
Got it working!
For some reason my playercorefactory.xml was only 0KB in size after i extracted it initially.
I just extracted the zip again and now it is 1KB in size so copied it into the XBMC userdata folder to replace the bad one and now all is working fine
MX player now being used for playback within XBMC
thats good to hearEverything is possible if we work together!
Originally posted by lewy20041 View Postthats good to hear
Regards
Peter.
ps...where can I go to take a look at different skins?...I'm not keen on the Xperience skin, just want to see if there's anything different to the default
check out this treads:
Regards
Peter
for weeb.tv use this http://www.multiupload.nl/WO9NCTD0DM also this i for mx pro if you have free wersion edit xml and change pro to ad.Everything is possible if we work together!
When transferring playcorefactory, i can only get to the folder:
Android/data/org.xbmc.xbmc/files
how do I get to the .xbmc/userdata. portion of the folder.
Also, having a hard time choosing MX player as defualt, still defaults to the XMBC. I have been all through the settings, cant find a way to choose defualt. Some have said press "c". When, and where?
Still cant get DTS working. Shows PCM on everything I am playing.
Thanks for the hard work, and would love some info on how to fix.
Originally posted by flynreelow View PostWhen transferring playcorefactory, i can only get to the folder:
ThanksEverything is possible if we work together!
Plexbmc
Have any one tested this with the plexbmc addon? I use plexbmc on the raspberry and ipad to remote connect to my media on another location. The add on works on my mk808 but has the same problems with hd movies. There is a plex app for android but it works very bad and we cant change subtitles size that are very very small. If any one could test this please let me know. Thanks
Originally posted by fleshfly View PostHave any one tested this with the plexbmc addon? I use plexbmc on the raspberry and ipad to remote connect to my media on another location. The add on works on my mk808 but has the same problems with hd movies. There is a plex app for android but it works very bad and we cant change subtitles size that are very very small. If any one could test this please let me know. Thanks
There are currently 2307 users online. 0 members and 2307 guests.
