Modded Hulu Plus APK?
Yes, I would like that, too.Randy
the xda one says its from january this one say may it might be the same one not sure http://forums.acsyndicate.net/showth...-FULLY-WORKING
alternativly you can install splashtop2 or splashtop hd this app streams the whole computer screen so its better then remote desktop rdp. with rdp you cant view videos or play pc games splash top allows android to do every thing your pc can. i just tested the netflix website on mk808 using splashtop in hd the voices were way off but if played in sd it laged a little and the voices were almost synced. so iif some one with better knowledge or ethernet connection this way may work
theres also a splashtop game app thats sullposed to let you play what ever games you can run on your computer threw android
----just tryied splashtop2 video played perfect no sync issues cartoons looked great live action movies quality was low
hulu stuttered on both versions of splashtop not sure about hulu plus i dont have an account
forgot to mention i may be running rooted stock rom. mine came rooted and im not sure if its a custom rom or notLast edited by white-enochian; 12-09-2012, 07:39.
Originally posted by white-enochian View Postalternativly you can install splashtop2 or splashtop hd this app streams the whole computer screen so its better then remote desktop rdp. with rdp you cant view videos or play pc games splash top allows android to do every thing your pc can. i just tested the netflix website on mk808 using splashtop in hd the voices were way off but if played in sd it laged a little and the voices were almost synced. so iif some one with better knowledge or ethernet connection this way may work
there is no 2.x version of Hulu Plus that has been modded to run on any device yet. The 1.x version is still out there if you look hard enough. I have it on my mk808 and it works very well. The interface leaves something to be desired, but it plays what you want it to play, which is the important part.
Originally posted by nalf38 View Postthere is no 2.x version of Hulu Plus that has been modded to run on any device yet. The 1.x version is still out there if you look hard enough. I have it on my mk808 and it works very well. The interface leaves something to be desired, but it plays what you want it to play, which is the important part.
Originally posted by 123421342 View PostWant to share where you got it from?
There are currently 2452 users online. 8 members and 2444 guests.
