MK808 and USB Hub
MK808 and USB Hub
Guyz does the usb hub have to have power supply? I purchased this one http://www.****.co.uk/itm/3209519906...84.m1439.l2649 and whenever i connect more than 1 usb device, they wont work. When i connect only 1 it works.. I guess this means more than 1 device is not powered enough by the mk808 power supply alone and i need a hub with power connection right?Tags: None
Originally posted by Warlord1981 View PostGuyz does the usb hub have to have power supply? I purchased this one http://www.****.co.uk/itm/3209519906...84.m1439.l2649 and whenever i connect more than 1 usb device, they wont work. When i connect only 1 it works.. I guess this means more than 1 device is not powered enough by the mk808 power supply alone and i need a hub with power connection right?
Best of luck!
this is why i cant have a external harddrive that has a y power cable. i plug the power plug from the harddrive into the tv and the power feeds back threw to where i have to unplug both caples to turn of the mk808 something that would also help is try using a psp powersupply that plugs in the wall it works great i made a thread about this a wile ago
Originally posted by white-enochian View Postthis is why i cant have a external harddrive that has a y power cable. i plug the power plug from the harddrive into the tv and the power feeds back threw to where i have to unplug both caples to turn of the mk808 something that would also help is try using a psp powersupply that plugs in the wall it works great i made a thread about this a wile ago
There are currently 2816 users online. 0 members and 2816 guests.
