Dell
IF YOU WANT FLAWLESS PLAY TRY VIDEOMIX
Hi all i have just started using Videomix from app store and it plays flawlessly this is how XBMC should be, If others can do it then why not XBMC i will not be using it now that i am using Videomix it asks you what player to use if you have more than one i use MX Player not everything plays but that is more to do with video source than anything give it a try.
DellTags: None
I tried it. It works well on my N101 and N70.
I'm not sure how legal the content is. There are several movies that are CAM's. Good quality, though.Randy
Re: IF YOU WANT FLAWLESS PLAY TRY VIDEOMIX
Originally posted by Dell View PostHi all i have just started using Videomix from app store and it plays flawlessly this is how XBMC should be, If others can do it then why not XBMC i will not be using it now that i am using Videomix it asks you what player to use if you have more than one i use MX Player not everything plays but that is more to do with video source than anything give it a try.
Dell
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
There are currently 2457 users online. 1 members and 2456 guests.
