So how do you go about increasing the app storage memory to say 6-7gig to take up all the internal memory on the device? I found a few apps but they were for specific phones and would not cut it. Hoping Finless will chime in since I know he increased one device grom 1gb to 1.5gb and another to 2gb.
How do you increase the app storage size??
So I have a iMito MX1. It has a small 1gb app install area. What I have done is added a 750Gb harddrive and setup my iMito to use that as the "NAND" storage. So far that is working great, but now I have all the internal memory going to waste.
So how do you go about increasing the app storage memory to say 6-7gig to take up all the internal memory on the device? I found a few apps but they were for specific phones and would not cut it. Hoping Finless will chime in since I know he increased one device grom 1gb to 1.5gb and another to 2gb.Tags: None
The only way is to modify the parameter file and increase /data space. Then you have to do a full reflash of the ROM as NAND has to be repartitioned with the new parameter file.
I can whip you up a parameter file that will use all but .32gb of internal (you really need some area here for compatibility). /data will then be 6gb
That would work and once I look at it I'm sure I'll know what's going on and can adjust it as needed.
I do have one other thing. I am having trouble opening the iMito roms from the factory. I have an Epic 4G touch and don't seem to have the same issue. Can you throw me some info on that. Win7 PC BTW.
Hang tight.... My new ROM I will give you a choice when you flash to pick 1GB, 2GB, 4GB, and 6GB.
Originally posted by reddragon72 View PostSo I have a iMito MX1. It has a small 1gb app install area. What I have done is added a 750Gb harddrive and setup my iMito to use that as the "NAND" storage. So far that is working great, but now I have all the internal memory going to waste.
I thought it will be easy with directory bind app or simply mounting it, but no, I'm stuck
There are currently 2060 users online. 4 members and 2056 guests.
