iMito MX1/2 - Finless ROM 1.5 - Root, debloat, init.d support
Crashes
Successfully flashed 1.5.
Looks ok, turned on Wi Fi got connected to the local network and Internet, turned on Bluetooth and paired with my keyboard.
Clicked on browser - the whole system crashed and rebooted.
After system came up again, tried to open Google store - the same, crashed and rebooted.
Anybody experienced these issues?
I have MX2.
Originally posted by sewhuy View PostHave you tried using a different power supply and not the POS that it comes with?
I am actually using some other POS power supply I had home just because of it's smaller size. I thought all USB power supplies are made to the same specs.
Thanks, will try with original and with some others I have if the original will have the same problems.
Originally posted by sewhuy View PostTry something with at least 2 amps to be safe.
The original adapter rated 2amps.
The one I was using rated 0.5amps so this was the reason for reboots.
Here comes another question: I have USB ports on the back of my TV right next to HDMI port.
Would I be able to draw enough power from one of those?
Sorry for question not directly related to this great ROM.
Re: NEW - iMito MX1/2 - Finless ROM 1.5 - Root, debloat, init.d support
Originally posted by NY_HAMMER View PostI was under impression that you root the device not the ROM.
Did I just make that more confusing? lol
Originally posted by lifeisfun View PostWhen I use the Reboot app there is several options including reboot to recovery.
I thought this will enter CWM but all I get is Android robot on his back with red triangle.
Do I have problem or CWM is not installed when you flash this ROM ?
Originally posted by fr0d0 View PostPlug into another TV and change the settings
Originally posted by anhell28 View Posti have connected it to a sony hdtv and it worked but i want to use the imito mx2 on my large screen vizio in my living room.what settings do you suggest i change as it wont even boot up on that particular tv.
Don't know if you planning to make other updates to this ROM but if you do
would it be possible to flash them using CWM?
There are currently 2110 users online. 2 members and 2108 guests.
