Is there a way to remotely turn on Imito MX1?
Hey everyone, I just installed the Finless 1.5 ROM and I am enjoying it. There is a soft power feature to turn off the device, which is great, but I was wondering if there was a way to turn it back on remotely? I am currently using my phone via droidmote to control the Imito MX1 and was hoping to find a solution to turn the device back on while still using my phone. Thanks.Tags: None
No, there is no way. Only way is to unplug it and plug it back in.
Originally posted by Bug Splat View PostWhy turn it off? I never turn off my Android phone, never turn off my 3 android tablets, they are designed to just run 24/7. Just leave it on, they draw almost not power. The less you power cycle electronics the longer they last.
Mobiles and tablets are meant to operate continuously, but they are not meant to keep continuously under power supply. I believe continuous charging of mobile device for days can damage mobile device.
So, I am not sure how our mini PC devices are meant for?
If someone in contact with manufacture can confirm this? I believe everyone has this doubt and no one 100% sure...
Re: Is there a way to remotely turn on Imito MX1?
Originally posted by RmatriX1218 View PostI would love to keep device on the way you said, but I am also confused...
you are NOT charging the mini PC since there's no battery in it
the continuous charging damages only batteries.
Sent from SGS III GT-I9300 🙋🙎🙍🙇🙅🙌
Originally posted by savvas42091 View Post... but I was wondering if there was a way to turn it back on remotely? ...
I haven't actually done it myself but there is no reason why it wouldn't work.
The reason I was thinking about it was that way I could turn the whole lot on or off with my harmony remote.
If you don't know what I am talking about Watts Clever is one company that sells them.
Ctrl+alt+delete does work on a USB keyboard but I do not see how it could work with a wifi keyboard as when it's off, there is no wifi!
Originally posted by Finless View PostCtrl+alt+delete does work on a USB keyboard but I do not see how it could work with a wifi keyboard as when it's off, there is no wifi!
Originally posted by morias View PostI thought about this previously and thought if I got a one of those "green" power points or power boards that come with a remote so you can switch them off remotely that would work. You would need to power the MX1 with a USB adapter which plugs into the power point.
Hi all,
i flashed iMito MX1/2 - Finless ROM 1.5 to my ug007 all is brilliant and I confirm I can start the ug007 via FN+Enter/ Control+Alt+Delete.
Im using this http://m.aliexpress.com/item/457421084.html.
Boot time varies but all works.
Thanks bob for all your hard work.
There are currently 2706 users online. 3 members and 2703 guests.
