MK802 IIIs which Rom can I use?
    Hello,
    I just got the Rikomagic MK802 IIIs and was wondering which finless rom I can use?
    Bluetooth is not important for me right now, so if it wouldn't work .. Np
    can I use any Mk802 III rom? Which device is equal ? MK808 and ug802?
    I would love a 1080p
    Ty in advance
    See this thread
    Many are using the ug802 1.7 ROM. BECAREFUL to not use a kernel overclocked past 1200 or you will cook your MK802-3
      See this thread
      Have heard from another person that the MK802 IIIS has completely different WiFi and Bluetooth chipsets from the UG802. Doesn't that mean the MK802 IIIS will not work with the 1.7 ROM?
        Yep, that's right. Wifi and BT not working :/
        I am waiting for my USB LAN Adapter, that would fix the Internet problem for me.
        Maybe there ll be a rom for us in the future.
          MK802IIIS 8G with Bluetooth can use "iMito MX1/2 Finless ROM 1.5"
          MK802IIIS 4G/8G without Bluetooth can use "UG802 2dark4u/Finless ROM 1.7" or "MK802III Official Firmware"
            Ty. Is there a big difference between the 1.5 mx and the 1.7 ug802?
              yes there is a diffrence between ug802 and mk802s they are almost the same except mk802iiis has wifi bluetooth chip and 3 usb ports (1 full size 2 small with a included small to full size adapter) and has 8gig space. ug802 has a diffrent wifi chip and only 4gig space! the ug007 is much closer to mk802iiis as they both have 8gig and bluetooth
              so far i think the mx1/2 1.5 finless bob rom works with it though but i havent tried yet!
              Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
              HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
              ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
                I tested both roms and all I can say is I prefer the UG 1.7
                I had a few freezes, lags and stuff with the Imito Rom.
                As soon as I get my Ethernet Adapter I ll go back to the 1.7 ROM
                  on ug 1.7 rom, wifi and bluetooth dont work?
                    Nope, different wifi chip
                      Finless 1.5 on MK802 IIIS
                      Can I flash finless 1.5 on my MK802 IIIS and expand the internal storage to 2gb? Can I revert to stock firmware if I don't want finless anymore?
                        Revert ROM = install other ROM
                        In MK802-IIIs you can revert installation of ROM or CUSTOM ROM (Finless 1.5) restoring to another ROM. The best process is using RESET button Technique.
                        _____________________
                        Sticks/TVBoxes: UG007, UG802, MK802-3s V3 & V4 & V5, MK802-3, V8 & CX-803, B12, Minix Neo X5 & G4, MK808, MK808B, CR8, Hi-802, iMito MX2, Mele A2000, MK806, CX-921, CX-818, CX-818B, MK808C (A20), MiniTVBOX A20, Bluetimes M8, Pipo X2, ...
                          Revert Finless 1.5
                          I heard from other users saying it is not possible to install stock image after installing finless that's why I wounder. I havent dared installing finless because of this. Thanks!
                            Testing now....
                            From Finless 1.5 iMito MX1 to Official ROM 20121212 in MK802-IIIs
                            works!
                              revert finless 1.5
                              Super! Thank you.
                              Does finless 1.5 work well on IIIS? I'm gonna flash 720 kern
