Finless works better than Official ROMS 1212 and 2012.
MK802 IIIs which Rom can I use?
Originally posted by Svensson View Post
Finless works better than Official ROMS 1212 and 2012._____________________
Sticks/TVBoxes: UG007, UG802, MK802-3s V3 & V4 & V5, MK802-3, V8 & CX-803, B12, Minix Neo X5 & G4, MK808, MK808B, CR8, Hi-802, iMito MX2, Mele A2000, MK806, CX-921, CX-818, CX-818B, MK808C (A20), MiniTVBOX A20, Bluetimes M8, Pipo X2, ...
Originally posted by Svensson View PostThank you! Will the revert to stock image work even if I change internal partition to 2gb?_____________________
Best rom ever! I have tested all night streaming video, playing games, listen to music and didn't have any freeze,hang or reboot!! :-) My old problem is still there though.. Some games and movie streaming apps won't play in full screen. There's a big black border around the screen making it very small. Any tips getting full screen?
Originally posted by Svensson View PostBest rom ever! I have tested all night streaming video, playing games, listen to music and didn't have any freeze,hang or reboot!! :-) My old problem is still there though.. Some games and movie streaming apps won't play in full screen. There's a big black border around the screen making it very small. Any tips getting full screen?
You might be able to tweak LCD density in build.prop to get it full screen but that will require a reboot each time to switch back and forth.
Machinarium (game) and viaplay (streaming). the app is in full screen, but the player got a frame. I pay monthly for the service, so it is a bit annoying. I heard that edit one XML file could solve it. I can set the screen size to full and it works but everything else (menu, ui) is outside the screen so I have to change it back when I'm finish.
I had sound and video issues while playing flash player streams with the imito 1.5
I tried a ton of different browsers and flash player versions, nothing helped. Now I am back at the newest Rikomagic firmware
I hope finless will create a custom rom for us. With the stock rom I had more than 1000 points less at antutu benchmark (compared to the 1.5)
Go for it bob
Originally posted by Svensson View PostIs there any guide for V6 supercharger on finless 1.5?
I tried and only got 50% and many errors... :-(
Okay, I finally installed the stock OS using the reset button technique. Back to square one. My only question now is how to I get this darn Finless rom to install!? I've tried both USB ports on my computer. Drivers are installed correctly. Using the finless rom flash tool and maintaining the stock settings. Where am I going wrong? Can't get the finless 1.5 to get past boot screen, but stock rom restores without issue. Help?
hi . i have the same MK802 iiiS. but all "S" versions have WIFI & BT issues and lots of drops .the link that you've given is about MK802 iii and NOT about MK802 iiiS !!!!!
can you pls pls pls pls create a Thread especially for MK802 iiiS ?!!
where we can inform us about ( Frimwares , Issues, Comparison, ...)
***which one do you prefer personally ?(better)?
-Rikomagic MK802 IIIS
-iMito MX2
-MK808 B
which one has better WiFi/BT and less issues ?
There are currently 3742 users online. 1 members and 3741 guests.
