Unusual problem
Re: Unusual problem
Not certain if there is an easy way to resolve but here's a few ideas. These will reset the tab fully so you will need to reinstall apps and your data will be lost.
1 shutdown and restart in recovery and look for the wipe options. Select these. Restart and setup the tab again.
1 shutdown and restart in flash/bootloader mode. Reflash the ROM.
Hope you get it resolved.900Supersport
freaktab developer
Re: Unusual problem
This link might help and make sure you follow the xda developer links http://www.redmondpie.com/bypassing-...gging-enabled/
Sent from my unknown using Tapatalk 2
Originally posted by 900supersport View PostNot certain if there is an easy way to resolve but here's a few ideas. These will reset the tab fully so you will need to reinstall apps and your data will be lost.
How do I get to restart in recovery?
Re: Unusual problem
From memory, force the tab off then press and hold volume+, press power for 5 seconds. Hopefully the tab will start booting, release power and then volume.
If this does not work I'll check with my mini.900Supersport
freaktab developer
There are currently 2453 users online. 0 members and 2453 guests.
