Does any one have any ideas on how to correct this on a rooted device?
Arnova 9 g2 - portrait screen upside down
I have noticed that some apps appear to be upside down when launched - by this i mean that in portrait mode i would expect the ports (usb, sd card, etc) to be at the top. From what i can tell there seems to be som default setting somewhere which is 180 degrees wrong in portrait mode.
Does any one have any ideas on how to correct this on a rooted device? -
This is the same for the 10 G2. What some consider upside down may not be considered by others as upside down
It's in the ROM how the tablet decides orientation. I will look at this later but for now that is how Arnova made it.
Originally posted by Finless View PostThis is the same for the 10 G2. What some consider upside down may not be considered by others as upside down
How to tweak accelerometer axes
try some of following properties:
accelerometer.flip_xy=1
accelerometer.invert_x=1
accelerometer.invert_y=1
accelerometer.invert_z=1
these can be set from shell e.g. setprop accelerometer.flip_xy 1. after setprop, auto-rotate off->on to reflect properties. once you get correct settings, add necessary lines into /system/build.prop. in most cases, one of followings will work:
or
Maybe could be included in next custom ROM?
Originally posted by chidave09 View Postpulled this off the Rockchip CM7 project page, it says to open term and setprop ..., but of course you can just edit build.prop
Forget it.... SOme of us tried changing these values and it did nothing.
It's going to be a driver that controlls this. I know Fenice57 might be working on a fix for this.
Originally posted by zemanuev6 View PostHi, i use an app called "orientation control". With it, you can set the tablet in "reverse portrait mode" from notification bar.
RegardsPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
There are currently 1038 users online. 0 members and 1038 guests.
