USB2.0 - LAN Adapter HG20F9 - Driver?
After reading that post on slatedroid, it appears that KO is not for this kernel.
Let me see if I have one for Jellybean 4.1
Originally posted by nbuuifx View PostCan't think of much else!
Try disabling any network, use advanced task killer to kill everything you possibly can.
If you are using terminal emulator try using the adb shell instead.
Running out of options without trying it myself.
Thanks,
MarkusAttached Files
Only thing I have is a axis.ko module compiled for JB kernel 3.0.8+
See if it works.
BobAttached Files"Pzebacz im, bo nie wiedzą, co czynią"
Originally posted by Finless View PostOnly thing I have is a axis.ko module compiled for JB kernel 3.0.8+
See if it works.
insmod: init_module "asix.ko" failed (Exec format error)
I am still running your 1.6 ROM, haven´t upgraded to 1.7 yet. Shouldn´t matter, but just in case.
Markus
Originally posted by markust View PostCan you? You don´t need the actual device, as the error occurs already before I plug it in. The driver can be found here:
Thanks,
Markus
Originally posted by Finless View PostAfter reading that post on slatedroid, it appears that KO is not for this kernel.
Originally posted by nbuuifx View PostI can give it a go, I've done a bit with linux but must admit I'm no android expert. Not got time tonight but will try and have a go in the week. Although to be honest it sounds like Bob thinks it's for a different version so it might be a non starter without recompiling.
After the alternative "USB 2.0 to RJ45 LAN Ethernet Network Adapter" that I bought from geekbuying.com turned out to be only USB 1.1 and thus limited to ~6Mbps throughput (unusable for 1080p videos), I would really like to get this HG20F9 device working, as it´s a real USB 2.0!
Thanks,
Markus
Did someone recompile this driver for kernel 3.0.36+
Can some share it, or how does remcompile works?
Originally posted by michel30 View PostDo you have the LAN driver ?
Do you want me to post the zipped cd (112MB) somewhere? Is there a place here on Freaktab to put it?
There are currently 7023 users online. 2 members and 7021 guests.
