My younger brother and I both purchased imito mx1, he lives in Paris and he orderred it from ****, I on the other hand live in Florida , USA and decided to get it straight from china from geekbuying.com. My imito never got the option to 1080p as I was expected. It came already "fixed up" for 1280p x 720p both options (60 hz and 50 hz). I tried to do everything in my power to upgrade the mx1 to the 1080p resolution, root it and upgrade it with an update.image file. All I got was to see it stuck in the "imito mx series" screen. He on the other hand got one with the 1080p option already. My brother doesn't have to root it or experiment with it to get the best resolution according to what he wants to see on the screen. My best advice to those hoping to get one:
NEVER PURCHASE A DEVICE FROM A COMPANY THAT DOESN'T CARE IF YOU HAVE A PROBLEM AFTERWARD. Make sure that when you pay for it you are somehow protected to get your money back if you're not satisfied with the item. I'm sure the imito that I received was already "fixed" by those guys at geekbuying.com... because my brother's came already with all the resolution screen options the first day.
I lost $60.00 by dealing with those guys.... don't be another victime of greed and irresponsability.
this advice is free.
thanks for your attention.
.gif)
.gif)
.gif)
last minute note: I'm not looking for getting my money back if that's what you think, I only wanted to get what I paid for. Even a fair exchange for a second one having to pay for the return would have been in order... honesty is something that comes with LUCK in those "miracle devices" made in China these days.
