MORE warnings about UG802 CLONE!
how to reboot to flash mode
There is one another way how you can reboot to flash mode. I tried Bob's way, but it's not working for me, after I switched device from media device to usb storage (and I tried it many times and fast after I switched it) that damned thing not want reboot to flash mode.
OK. I installed this utility:
https://play.google.com/store/apps/d...XVpY2tib290Il0.
and choosed reboot to bootloader.
It was reboot to black screen and start installing drivers.
Then I was be able to flash device.
Finally got to open my ug802.. Took some pics..
pcb is labelled as T002 V2 20121207. I think i see a reset button. Wonder of someone else got this and if anyone tried to flash wih finless?? Thanks.Last edited by jakkuchan; 01-27-2013, 06:02.
Jakkuchan,
Please don't flash 1.07 yet. I did that and lost Wifi!
Please make a backup of the firmware first.
I didn't look deeper into how to achieve that, but at least the original kernel-image should be helping already. There is something different with the Wifi setup although the chip seems to be the same, Realtek RTL8188EUS.
Please, look through the posts here and find a way to dump that firmware!
I would dare to flash back parts of it to find out whether this works at all and would try to find the difference.
Edit: It seems, the vanilla firmware is already available!
Is this a clone too?
Hi guys,
just recieved that thing and wifi is terrible and googeling brought me here looks like stock rom has a weak wifi and finless fix that!!!
my question is my unit a clone and finlessing it would brick it ?
I need a link or so for backing up and restore stock rom just in case
hers is my unit details
Originally posted by chrizzl View PostHi guys,
i received my UG802 today, however it only says "dual core CorteA9 RK3066 for Android 4.1" on the front. Here some pictures of it. It does not even have a wifi antenna!?! The wifi-reception is not bad, though. Can anybody tell me what this is?
This is NOT a ug802 clone but a totally different stick!
worked like a charm
Hi Bob,
I installed finless 1.7 , looks great but didn't really help my poor wifi reception , I saw your videos on
youtube about sticking the antenna out but again didn't help much
and the one about cutting the ground shield cause of short and that wasn't a problem
it was meant to be connected together on the antenna side (which look like a z letter in my unit)
so I tried to cut the shield and now guess what now its working much better with no drops in signal
Yeeea I've a working stick , now need to find some cool apps to play with
so if one out there have a unit like mine (see my previous post for pics) you know now what you ve to do
thx Bob for your great site tips, videos and everything
there's very crappy Rom installed.
Thank you very much
Originally posted by angelobiz View Postnot all clone are same. i have a clone... but on it work All!... Finless rom is ok, mk802III firmware is ok, recovery is ok and mode for unbriking is ok, no reset button.
when you buy somethings by china... you know always what you order... but you never know what you will have... :-(
Originally posted by jlunse View PostI'm trying to summarize this:
- You do NOT have a reset button and everything works fine, correct?
( No reset button= Everything works fine.)
- The problem seems to be on those UG802 who do have a reset button.
( Reset button= Seems to give problems.)
UG802 "reset button+Realtek" V2 - Finless ROM
Hi Bob!
I have an UG802 categorized here in the forums as V2. It has the reset button, wich seems to work, and has a Realtek wifi module. It's the same type MGa73 has. We are both from Hungary, and probably got it from the same batch. I'd like to flash Finless on it. Preferably one of the latest versions, but read the forums first, and realized, that this would break the wifi, wich is a must have for me. But the original ROM is not fully rooted wich turned out to be a problem aswell. I'd like to use some touchscreen apps, and play games therefore I bought Bt/USB Joystick Center app, to calibrate control schemes to my usb gamepad. The app needs proper root, so itdoesn't work at the moment.
I found a few posts, that some of the guys with these devices managed to get wifi working with installing your ROM and then reflashing the original kernel.img. Is there a chance, you would make a flashable Finless 1.7-1.8 ROM for these V2 devices, using the original kernel, as you made one for those "on pcb wifi antenna" clones? I'd be happy to beta test it! And I'm sure MGa73 would participate aswell.
An other thing i'd like to ask about is a strange issue I noticed. I use a powered USB hub with the device connected to the standard USB port, and It powers up my Ug802. On the pcb theres the overcurrent protection circuit, but I started to worry about this lately. I used to connect the hub after powering up the stick from the TV, but last time, I did'nt notice that someone pulled the USB plug, and was surprised to see that it powered up after connecting the active the hub...
Sry for my bad english... I haven't been using the language lately.
There are currently 2597 users online. 4 members and 2593 guests.
