Finless Bob's Rom - Debloated (more to come)
Hey Dave, re: kernel inside of boot.img. Yes many Roms like most RK28 Roms the kernel is inside of boot.img along with a ram disk.
New Version Up!!!!
After flashing and playing around I discovered the beta for the most part works! A couple minor tweaks need to be done, but decent for now. One problem though, when I added more google stuff, I accidentally used an older package, lol.
Anyway, I am going to start building my own rom from the ground up with all the stuff Bob and others taught me. So, keep an eye out, and let me know what you think of this betaLast edited by chidave09; 16 February 2012, 02:47.
Originally posted by x51 View PostWill this format the tab? (Set me back to stock?)
*on a side note, I am sorry for the lack of updates and such. It has been a very haptic week and I am expecting one more, so please bear with me, I will be here as much as I possibly can be.
Originally posted by chidave09 View Postit will NOT set you back to stock, it will give you a stock rom that has been converted to the ext3 format, rooted, and debloated. If you want stock you need the update from polaroid's website. If you are trying to fix a so called "bricked" tab, I have posted directions for this. What ever your reason, let me know the reason, and I will point you in the right direction.
I guess I mean.. will flashing this new version over your old version format the tab (I.E. Remove all my installed apps and settings) or will it just update the version I have installed (Keeping all my apps and settings).
If your coming from Stock to my ROM or Dave's you have to eraseIDB so yes it will erase everything.
If your coming from Dave's previous ROM or mine then you can just flash system.img. HOWEVER! Anything you put in /system will be gone. You may also have some anomalies with programs that use root.
Bottom line it is always best to erase to make sure you are clean.
Originally posted by Finless View PostIf your coming from Stock to my ROM or Dave's you have to eraseIDB so yes it will erase everything.
There are currently 2829 users online. 0 members and 2829 guests.
