is very similar to archos 10g2. I can unpack and repack boot.img (changed init.tr) repack (system.img -> ext3, deleted few unused apps so system.img is smaler than original cramfs) but after flash my tablet not start.
This is link to my original rom:
I was able to flashmy 10 G2 with this ROM and it boots. Of course the touch screen does not work but this is good as I can test full root setup and make sure it boots before I publish a ROM.
Let me download your converted ROM as well so I can look.
Never mind on your converted ROM. I have this one apart and should be pretty easy to make a ROM.
Give me a little time.
It will have all of the features of my other 1.3 ROMs for the Arnova, Polaroid, and Nextbook7.
I have not removed any of the built in apps so you will get what you had before. If you want me to remove stuff let me know.
Now before I publish it can you tell me the instructions for how to put the GoClever into FLASH mode please. I want to update my readme instructions.
Thaks,
Thaks,
GoClever into FLASH mode:
- Make sure the tablet is powered on and plug in the USB cable.
- Using a paperclip, press the reset button
and you are in flashmode
I found clone of my goclever and now testing this ROM (model NOVA S-M908HC):
Artural, looking through the built in apps in the stock ROM it looks like Market 3.4.4 is already installed?
Is that correct? I injected my Market 3.4.4 but it may not be needed?
Question again on the Market. I see the Market344.apk however I think it is very stripped down. In your apps drawer do you have a calendar app? Does the contacts and sync with goolge work like for EMail contacts? Do you have Gmail with it?
If not I think my Market files will be better for this ROM.
What do you think and let meknow about above.
Contacts - sync ok
Calendar, Gmail, Youtube - not installed in stock rom
I think you can add all this google apps.
OK good. I am going to cook a ROM with my Market files. Even though this ROM boots on my Arnova 10G2 so I can make sure it is not a brick ROM , the touch screen does not work so I cant test anything. You will be my first tester.
So you almost ready? Are you going to be around for about an hour longer?
Yes I'm ready to test new ROM yesterday was too late (night)
