Need help with Goclever R93
Yes I am in process. I was working on something else and got distracted but now I am working on getting this out. Should be about an hour or so.
Full root ROM is uploading the the server now.
I am going to run and get breakfast, coffee, etc and will post a link very soon!
OK here you go. I am calling this 1.3 since it includes all the mods I have done for other tablets to date.
Here is what is changed:
1) System.img is converted to ext3 from cramfs allowing it to be RW
2) I gave more space to /system to allow root capable apps to install or use space in /system
3) Maximum amount of app install space to /data has been setup (1 gig)
4) SU and Superuser.apk installed and files system given full root access
5) ADB debugging and USB ADB enable is set by default. You can turn that off in settings if you like.
6) I removed the stock Google Market 3.4.4 and injected what I think is a better Market 3.4.4 with some google apps. Calender, sync, etc should all work. But since I cannot test, let me know.
7) All pre-installed apps some may consider bloatware is still there. Let me know in V1.4 to come out later, if you want them removed.
This is not a update.img you can simply install to your SDCard! The structural changes to make this happen require that you use my ROM kit and follow the README to get the drivers installed and flash using RK Android tool 1.29. If you already have installed drivers for RKBatch tool, your good to go. Same drivers.
I have tested this on my Arnova 10 G2 and it boots. Thats as far as I can test. So if this jacks you up or bricks your GoClever, your on your own! The good news is using RKBatch tool you can recover using the manufacturers ROM update.img. Again though... your on your own with this ROM. I give no warranty or guarantee!
OK with all that said, here is my ROM for testing on the GoClever R93.
ROM -> GoClever R93 Full Root ROM with proper Market 3.4.4 - Version 1.3 By Finless (135 megs)
Let me know how it goes and again... READ the readme included please.
Later? Like how much later?
I always would like to know how it goes as soon as you can please. I don't want others finding via google this ROM and screwing up their Tablet. So the sooner the better please. Not trying to be hard on you but you posted this AM... "Any status". So I went to work.
Thanks! I was dying to know
No worries about the ROM. Please tell others that have the GoClever about it! It's OK!
I hope it works great for you and again others that have the same Tablet. PLEASE spread the word!
FreakTab is all about making peoples experience the best for their Tablet investment!
Anyway let me know how the testing goes.
After 45min testing:
- everything work
- system RW - ok
- system work little faster
- 1gb for apps - ok
- sync, contacts, gmail, - ok
- quadrant standard around 1330 - same like stock ROM
Did you try tweaks: build.prop, init.rc, libsqlite or something else ??
How can we made pinch zoom in web browser more smooth ? I try opera, dolphin, maxthon but pinch zoom is not smooth. Maybe GPU drivers from other tablets RK2918 could help ??
BTW, why I can't find freaktab in Forum Runner ??
After 24h everything work goodso I add some tweaks :
buid.prop
ro.HOME_APP_ADJ=1debug.sf.hw=1
windowsmgr.max_events_per_sec=150
pm.sleep_mode=1
ro.ril.disable.power.collapse=0
persist.adb.notify=0
debug.performance.tuning=1
video.accelerate.hw=1
net.tcp.buffersize.default=4096,87380,256960,4096, 16384,256960
net.tcp.buffersize.wifi=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.umts=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.gprs=4096,87380,256960,4096,163 84,256960
net.tcp.buffersize.edge=4096,87380,256960,4096,163 84,256960
ro.lge.proximity.delay=25
mot.proximity.delay=25
ro.kernel.android.checkjni=0
ro.config.hw_menu_unlockscreen=false
persist.sys.use_dithering=0
persist.sys.purgeable_assets=1
ro.mot.eri.losalert.delay=1000
Test Quadrant Standard now is around 1600, and overall I think now is little more smoth
There are currently 2284 users online. 3 members and 2281 guests.
