[ROM]PMID4311 Modified Stock
Originally posted by dolorespark View Post
Originally posted by elektrik View Postthat OEM partition is limiting what I can do with it. If I simply build the ROM without it, it fails to run. If I modify certain things and include it, the changes work on first boot, but are overwritten on next boot. I can't figure out what's making the changes after the first reboot, and I can't seem to 'crack open' the OEM fex to see what's inside (I thought it was cramfs, but apparently I'm either doing something incorrectly, it's encrypted or it's not cramfs-not sure).
Also, I'm pretty sure that the OEM partition is cramfs but from what I've read, there are different incompatible flavors. I can't remember if I finally got it mounted on the tab or if I had to do so in Linux. Either way, there wasn't much if anything worth saving (if you go back to the post for my CM10 announcement, you'll find a link to a package with all the apps that were on the tab).
Originally posted by dolorespark View PostI'm at work right now, so I may get some details wrong, but... in init.rc, you should see something like "service preinstall" that runs a 'preinstall.sh' script. There's also a property trigger to start "preinstall" - I think it's "on sys.boot.completed". Look at the script (so you know what it does), then delete it and everything that causes it to run.
UPDATE: doloresparks advice did help-at least somewhat-I was able to get rid of that nasty OEM partition, however it's caused a few more problems I'm still sorting out-thanks dolorespark for the clarity I needed.
...with that said, I'm WAY past the point of just modified stock, so I'm just going to go all the way and push ahead to create 'Elektricity ROM' ICS for this little guy....
Originally posted by bbsux View PostI can confirm that the em543 v2 file DOES work with the pmid4311. It looks exactly the same but is branded a little different (boot screens, I don't know what else)
about reads
em543 instead of pmid4311
4.04
baseband 1.4rc3
kernel
3.0.8
Jul 5 15:16:33 CST 2012
build #
em543-20120726
There are currently 1610 users online. 0 members and 1610 guests.
