Does the MK808B suffer random Reboots/Freezes like the Imito MX1 ?
Originally posted by PoisonWolf View PostYeah, thank you leolas. Your guidance and trick for the dremel was helpful! It was still a tight fit however. I had to really shove the usb cable in there cause I didn't do it right. It did went in, but the USB head had some scuff marks. Lol., and not so much stetic but works well too
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYou need to break the plastics. You can do easy with a "dremel??" I dont know the world of the toolin english. Here I send u a photo I found in internet.
And yes, it reads only 1,5 but i see 1,8A without so many heat in it, while the stock one cant got more than 1,2A and getting hot.
Re: Does the MK808B suffer random Reboots/Freezes like the Imito MX1 ?
Originally posted by ahnah View PostOic ..just break the plastic ..REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYes, it's easy, if my brother can do it without problems everyone can do it ;P
Get the official PS VITA usb cable and then get a micro USB converter to a whatever USB head that the android stick uses.
This is a REALLY expensive way to go around it but hey...you get the keep the warranty of your PS Vita charger. Lol.
Originally posted by sammassam View Postcould flickering of the screen sometimes and random reboots be attributed to using a usb powered hub to power the mk808? if so is there any easy way to fix this ?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by ahnah View PostThe power adaptor purchase with MK808B says...
Model: LA-520 (is your the same as mine ? )
Input:100-240VAC0.3A 50/60Hz
Output: 5V----2000mA
When i go shopping mall to look for PS VITA power supply... any particular model to look out for ?
Originally posted by PoisonWolf View PostThe original by SONY.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by primy View Post**** link maybe?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostI suggest to bought it in amazon or in a shop center better, ensure the original one.
When you buy a USB charger, how do you know if you're getting a safe, high-quality charger for your money? You can't tell from the outside...
They are available at a number of places and I don't think you need a dremel to get it to accept a standard usb cable.
http://www.****.ca/itm/171069719959?...84.m1497.l2649
http://www.****.com/itm/HP-TOUCHPAD-...-/261180890798
I hope this helps.
Originally posted by mpp View PostThere is another option that has been independently tested as a good power supply. It is a genuine HP touch pad charger. Test article here:
I hope this helps.
There are currently 2451 users online. 0 members and 2451 guests.
