InsertCoin25
Older - Minix Neo X5 Finless Custom ROM 1.0
PS3 Sixaxis
InsertCoin25
Originally posted by CowPL View PostI get today my new X5 (AleX Wong is good seller), flashed Finless ROM and is nice, but in 1080p kernel I have very small icons and very small text
I can't read in my TV
Edit build.prop. Set LCD Density to 240. Now icons will be big again like 720 kernel.
Originally posted by newuser121 View PostHi guys, how can I disable or change that HORRIBLE custom intro fro the ROM that we see instead of the MINIX intro? No offense Bob, and thank you for your work, but that intro looks very ghetto, lol.
You know.... I was going to make a long drawn out post about this subject but I have had a cold for the last 3 days and I am having a couple shots of whisky as cold meds right now
I am just going to leave my comments closed and post later.. But for now agree with what Lifeisfun said.
Use my ROM or not. If a simple boot animation which you can easily change yourself bothers you, then PLEASE... flash back to the stock ROM.
I will hold my tongue until I can respond better without having a cold or some whisky
If I get on my soapbox now... I will be a pissed off sounding post...... Which I do not want to do.
But....
Anyone want the lock screen back?
I have found how to enable lockscreen properly!
Funny they have it in the menus but it does not work.
So anyone want it back and are willing to test a new android.policy.jar from me?
I need someone that knows how to use ES FIle mananger as root to try it.
Excellent ROM Bob, many thanks!
I installed the 1080 kernel and boot image and changed ro.sf.lcd_density from 160 to 240, in build.prop. It looks great on my 47" Samsung TV.
Benchmark in AnTuTu gives me 9435.
I'm using it as a media device and so far only tested Netflix and our Swedish TV Player app and it all works really well. I have a lot more fun testing to do
It wasn't possible for me to get into flash mode by using the reset + holding power button for a few seconds, or if I misunderstood how to do it...I'm not sure. Anyway, I solved it by first rooting the stock ROM and in terminal entering bootloader with:
su
reboot bootloader
Many thanks for yet another great ROM!!
Sv: NEW - Neo X5 Finless 1.0 ROM
Originally posted by Finless View PostI have found how to enable lockscreen properly!
Please let me know what to do and I will test lockscreen.
su
reboot bootloader
any chance you could make a thread with detailed info on how to do this?
i have not been able to flash the bob rom,cant get it to connect to pc,
i did it before,it had 4.1 on it,which was very buggy and constantly froze,i was able to load the ICS rom to it,but now it will not connect,
your explailation may work for the vets,but for a newb like me,
step by step is needed,
thanks
BootlegGreg
Originally posted by BLG View Postany chance you could make a thread with detailed info on how to do this?
thanks
BootlegGreg
Read and follow the instruction carefully.
The only issue that I had was to get into flash mode, but it might have been just a mistake by me.
If you can´t get into flash mode, then there is a workaround where you first root it. Then install a terminal emulator from Google App store and just enter:
su
reboot bootloader
But again, follow the Finless readme.txt instruction is very important. Every step is described in it.
This means it did not shut off properly and corrupted the /data area.
How did you power it off? You did not just unplug it live right?
There are currently 3526 users online. 2 members and 3524 guests.
