video/power issues?
video/power issues?
Im starting to have issues with my 808. I dont know if its due to the 1.6 rom or if its a hardware issue. Every time I open an app the screen will go black like my monitor is searching for an input. After about the 3rd or 4th time it will stay black and ill have to power cycle the 808. Im thinking its either using a 1amp power adapter is taking its toll or maybe when I added the external antennas the solder gun heated the board too much? I dont know. Its been fine since November. Anyone else have this issue? Ive been able to run the stick and a ps3 controller and dead trigger with no issues so im not sure at this point.TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: PersusTags: None
Originally posted by kozmo2k4 View PostSounds like the power source is the issue. Other thing to try is different HDMI cable and port, even different monitor/TV.
But upgrading the power source to at least 2A will make your Android much more stable.
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Sent from my ASUS Transformer Pad TF300T using Tapatalk 2can anyone link 1.5 for me?
Kernel: Persus
Kernel: Persus
Well I got a chance to downgrade and still having the same issue. Looks like I have a bad stick. Sadface.
Ill probably upgrade to the Zeals Quad-Core stick when I have the money.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Good news! I figured it out. I decided to take one more look at it. Turns out the original heat sink on the opposite side of the CPU was not making contact with the chips. It was just barely floating above them and I could see light between them. This is how I fixed it...
I used a heatsink from a busted 360. This thing wont ever overheat again!TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Wow, yup that is cool.
I am still doubting the handyness of a stick. We all stick a usb hub in the thing, mod an external antenna etc etc
I am looking for a MK808 box where the connectors are more reliable, an external antenna, better cooling ... thinking about it it doesn't mean that it is alot bigger than a stick but much nicer.
Was it hard to get the heatsink off?
I hadn't posted the latest changes because I wanted to test for a day or so and make sure that was actually the issue instead of jumping to conclusions (mat) like I did so quickly before. Im running the new 1080p kernel and Bob's 1.6 rom and its running great. Streaming movies from my NAS to XBMC on the stick with no issues.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
OT: CWM?
OT: @Spotopolis which version of CWM are you using?
I installed the latest, version 6.0.2.8, from here: http://androtab.info/clockworkmod/rockchip/.
All is well, except the screen cuts off the first two letters on each line.... hmm.. screen resolution problem?
The TV is says it's receiving 720p when CWM boots up. It can handle 1080p, but I have the MK808 set as 720p, because it's only 32".
Sorry to hijack your thread....
Originally posted by kozmo2k4 View PostOT: @Spotopolis which version of CWM are you using?
Sorry to hijack your thread....TV Stick: MK808 // Tronsmart T428
Kernel: Persus
Originally posted by Spotopolis View PostI had the same issue. Its due to screen scale. If you tried another TV/Monitor it might fix it. I bet when you first booted the ROM you had to adjust the screen scale for it to fit you screen properly and in recovery it doesn't use those settings. Unfortunately you'll either have to wait for a fix or use another TV/Monitor.
Which version are you using? Any issue restoring from ExternalSD? I only made a backup so far, haven't tried anything else.
Originally posted by kozmo2k4 View PostThat's what I thought.... thanks for replying. I bought the MK808 for that spare bedroom TV; already have a G-Box Midnight on my main. Not a biggie, still can read it and I am familiar with CWM menus...
Its faster to back up to internal SD anyway and then later on copy it over to ExtSD or PC.
I'm still debating on either getting a Zeals GK802 stick or put some money down and get a ODroid-X2 dev kit.TV Stick: MK808 // Tronsmart T428
Kernel: Persus
There are currently 2778 users online. 0 members and 2778 guests.
