So I am asking you all to help us build a FAQ.
I will manage the input and build the FAQ. You all just make posts about items to go in the FAQ.
Now for incentive
The largest contributor to the FAQ, I will buy or get you a Android TV device of your choice!
It has to be limited to a Android TV stick or box and price of course has to be resonable (which they usually are). I am thinking less than $150 USD. But depending on contributions by the winner, this is variable and open to consideration.
So have at it! Make sure you post details! Just because you were the person to post the most here, does not mean you win! The winner is the person that puts in the most quality info that gets used in the FAQ!
Thanks,
